跳转到主内容
How to Replace a Watch Strap
你所需要的
  1. How to Replace a Watch Strap, Watch Strap: 步骤 1 中的图像 1,1
    • Begin by laying a soft towel or fabric on a table.
    • This will prevent accidental scratches during the repair.
    • We will be performing all repairs from the back of the watch, to avoid scratching the visible watch face.
  2. How to Replace a Watch Strap: 步骤 2 中的图像 1,2 How to Replace a Watch Strap: 步骤 2 中的图像 2,2
    • Before you begin, consider practicing with your tool to compress the bar.
    • Hold the watch with the face in your palm, with one end of the strap free to move.
  3. How to Replace a Watch Strap: 步骤 3 中的图像 1,2 How to Replace a Watch Strap: 步骤 3 中的图像 2,2
    • Insert your Spring Bar tool into the gap between the end of the watch strap and the watch body.
    • Press down and compress the spring. By pushing the bar away from the body, one end of the spring bar should come loose.
  4. How to Replace a Watch Strap: 步骤 4 中的图像 1,2 How to Replace a Watch Strap: 步骤 4 中的图像 2,2
    • Being cautious as to not damage the body or spring bar, slide the bar out from its hole and remove the strap.
    • Set this half of the strap with the spring bar aside until we remove the other strap.
  5. How to Replace a Watch Strap: 步骤 5 中的图像 1,3 How to Replace a Watch Strap: 步骤 5 中的图像 2,3 How to Replace a Watch Strap: 步骤 5 中的图像 3,3
    • Repeat steps 2-4 to remove the other end of the watch strap.
  6. How to Replace a Watch Strap: 步骤 6 中的图像 1,3 How to Replace a Watch Strap: 步骤 6 中的图像 2,3 How to Replace a Watch Strap: 步骤 6 中的图像 3,3
    • Replace the old or damaged watch straps by simply sliding the spring bars out and into the new straps
    • Be careful not to put the new straps on the wrong side of the body.
  7. How to Replace a Watch Strap: 步骤 7 中的图像 1,3 How to Replace a Watch Strap: 步骤 7 中的图像 2,3 How to Replace a Watch Strap: 步骤 7 中的图像 3,3
    • Begin the reassembly by sliding the bottom of the spring bar into its hole on the watch body.
    • Remember, always work from the back of the watch to prevent visible scratches.
    • Using your spring bar tool, compress the bar and slide back into place.
    • The spring bar should click when installed correctly.
  8. How to Replace a Watch Strap: 步骤 8 中的图像 1,3 How to Replace a Watch Strap: 步骤 8 中的图像 2,3 How to Replace a Watch Strap: 步骤 8 中的图像 3,3
    • Repeat step 7 on the other side of the watch.
    • Give the watch a tug to make sure all parts are installed correctly.
结论
You have completed the fix! We hope this guide has helped.
6等其他人完成本指南。
domenicruffino
于09/29/15注册
308 声望
撰写一个指南
团队
Cal Poly, Team 14-2, Green Fall 2015 Cal Poly, Team 14-2, Green Fall 2015 的会员
CPSU-GREEN-F15S14G2
4 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 61
总计 11,744
