跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
How to Replace a Turntable Cartridge, Stylus, and Headshell
你所需要的
  1. How to Replace a Turntable Cartridge, Stylus, and Headshell, Cartridge, Stylus, Headshell: 步骤 1 中的图像 1,1
    • Identify headshell by opening the turntable dustcover.
  2. How to Replace a Turntable Cartridge, Stylus, and Headshell: 步骤 2 中的图像 1,1
    • Remove stylus from cartridge.
    • Do not pull aggressively as to break the plastic.
  3. How to Replace a Turntable Cartridge, Stylus, and Headshell: 步骤 3 中的图像 1,1
    • Turn tonearm nut toward you to release headshell from the tonearm.
  4. How to Replace a Turntable Cartridge, Stylus, and Headshell: 步骤 4 中的图像 1,1
    • Remove screws with phillips screwdriver #0 to release the cartridge.
    • Use standard turntable head screws found at a local audio shop if missing
  5. How to Replace a Turntable Cartridge, Stylus, and Headshell: 步骤 5 中的图像 1,1
    • Unplug wires from pins.
  6. How to Replace a Turntable Cartridge, Stylus, and Headshell: 步骤 6 中的图像 1,1
    • Replace with new cartridge
    • Plug pins in reverse from removal
    • Pay attention to matching the colors from wire to pin
    • Screw cartridge in in the same way it was removed.
  7. How to Replace a Turntable Cartridge, Stylus, and Headshell: 步骤 7 中的图像 1,1
    • Insert new stylus into cartridge before mounting headshell
  8. How to Replace a Turntable Cartridge, Stylus, and Headshell: 步骤 8 中的图像 1,1
    • Screw assembled headshell onto tonearm.
  9. How to Replace a Turntable Cartridge, Stylus, and Headshell: 步骤 9 中的图像 1,1
    • Test new needle and allow for a break-in period.
终点
9等其他人完成本指南。
Javier Torres
于02/24/15注册
385 声望
撰写一个指南
团队
Cal Poly, Team 23-3, Green Winter 2015 Cal Poly, Team 23-3, Green Winter 2015 的会员
CPSU-GREEN-W15S23G3
6 名成员
创作了13篇指南
2条评论
"on any turntable"? These instructions are only for one specific tonearm and cartridge and apply to a minority of cartridges. This claim is plainly bogus and anyone with a different cartridge is likely to find the instructions useless and potentially hazardous to their equipment.
Howard - 回复
Just commenting to disagree with above. Excellent tutorial and my audio technical cartridge and headshell are similar so it solved my issue. Thanks for the article.
Craig Smith - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 43
过去 30 天: 190
总计 54,326
