跳转到主内容
加入维修社区 - 创建账户
How to Replace a Transition Strip (T Molding)
你所需要的
    1. How to Replace a Transition Strip (T Molding), Transition Strip (T Molding): 步骤 1 中的图像 1,1
      • Measure the exact width of the doorway using a tape measure.
      询问修复机器人
      添加评论
    2. How to Replace a Transition Strip (T Molding): 步骤 2 中的图像 1,3 How to Replace a Transition Strip (T Molding): 步骤 2 中的图像 2,3 How to Replace a Transition Strip (T Molding): 步骤 2 中的图像 3,3
      • Mark the T molding based on the doorway measure.
      • Cut the T molding using a sharp saw (table saw).
      • Cutting the T molding can be done for free at the place of purchase.
      • If you don't have access to a sharp saw, cut the T molding using a jigsaw and use sanding paper to soften the end.
      询问修复机器人
      添加评论
    3. How to Replace a Transition Strip (T Molding): 步骤 3 中的图像 1,3 How to Replace a Transition Strip (T Molding): 步骤 3 中的图像 2,3 How to Replace a Transition Strip (T Molding): 步骤 3 中的图像 3,3
      • Remove the old T molding.
      • You can use a pry bar to loosen the T molding.
      询问修复机器人
      添加评论
    4. How to Replace a Transition Strip (T Molding): 步骤 4 中的图像 1,2 How to Replace a Transition Strip (T Molding): 步骤 4 中的图像 2,2
      • Use a utility knife to remove all the glue or any material used to keep the old T molding in place.
      • You may use a scraper instead of a utility knife.
      • Clean up the area thoroughly.
      询问修复机器人
      添加评论
    5. How to Replace a Transition Strip (T Molding): 步骤 5 中的图像 1,1
      • Apply the glue evenly to the gap.
      询问修复机器人
      添加评论
    6. How to Replace a Transition Strip (T Molding): 步骤 6 中的图像 1,3 How to Replace a Transition Strip (T Molding): 步骤 6 中的图像 2,3 How to Replace a Transition Strip (T Molding): 步骤 6 中的图像 3,3
      • Insert the T molding into the gap.
      • Press the T molding firmly onto the ground.
      • No gap should exist between the T molding and the floorings.
      询问修复机器人
      添加评论
    7. How to Replace a Transition Strip (T Molding): 步骤 7 中的图像 1,2 How to Replace a Transition Strip (T Molding): 步骤 7 中的图像 2,2
      • Tape the T molding onto the floor.
      • This step ensures the T molding stays in place until the glue dries.
      • Wait 24 hours for the glue to dry.
      • Remove the tapes.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 24
过去 30 天: 169
总计 8,066
