跳转到主内容
How to Replace a Transition Strip (T Molding)
你所需要的
  1. How to Replace a Transition Strip (T Molding), Transition Strip (T Molding): 步骤 1 中的图像 1,1
    • Measure the exact width of the doorway using a tape measure.
  2. How to Replace a Transition Strip (T Molding): 步骤 2 中的图像 1,3 How to Replace a Transition Strip (T Molding): 步骤 2 中的图像 2,3 How to Replace a Transition Strip (T Molding): 步骤 2 中的图像 3,3
    • Mark the T molding based on the doorway measure.
    • Cut the T molding using a sharp saw (table saw).
    • Cutting the T molding can be done for free at the place of purchase.
    • If you don't have access to a sharp saw, cut the T molding using a jigsaw and use sanding paper to soften the end.
  3. How to Replace a Transition Strip (T Molding): 步骤 3 中的图像 1,3 How to Replace a Transition Strip (T Molding): 步骤 3 中的图像 2,3 How to Replace a Transition Strip (T Molding): 步骤 3 中的图像 3,3
    • Remove the old T molding.
    • You can use a pry bar to loosen the T molding.
  4. How to Replace a Transition Strip (T Molding): 步骤 4 中的图像 1,2 How to Replace a Transition Strip (T Molding): 步骤 4 中的图像 2,2
    • Use a utility knife to remove all the glue or any material used to keep the old T molding in place.
    • You may use a scraper instead of a utility knife.
    • Clean up the area thoroughly.
  5. How to Replace a Transition Strip (T Molding): 步骤 5 中的图像 1,1
    • Apply the glue evenly to the gap.
  6. How to Replace a Transition Strip (T Molding): 步骤 6 中的图像 1,3 How to Replace a Transition Strip (T Molding): 步骤 6 中的图像 2,3 How to Replace a Transition Strip (T Molding): 步骤 6 中的图像 3,3
    • Insert the T molding into the gap.
    • Press the T molding firmly onto the ground.
    • No gap should exist between the T molding and the floorings.
  7. How to Replace a Transition Strip (T Molding): 步骤 7 中的图像 1,2 How to Replace a Transition Strip (T Molding): 步骤 7 中的图像 2,2
    • Tape the T molding onto the floor.
    • This step ensures the T molding stays in place until the glue dries.
    • Wait 24 hours for the glue to dry.
    • Remove the tapes.
结论
Rojean Noorinayer
于05/12/21注册
145 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 88
总计 6,917
