跳转到主内容
How to Replace a Tail Light on a Nissan Pathfinder
你所需要的
  1. How to Replace a Tail Light on a Nissan Pathfinder, Tail Light on Nissan Pathfinder: 步骤 1 中的图像 1,3 How to Replace a Tail Light on a Nissan Pathfinder, Tail Light on Nissan Pathfinder: 步骤 1 中的图像 2,3 How to Replace a Tail Light on a Nissan Pathfinder, Tail Light on Nissan Pathfinder: 步骤 1 中的图像 3,3
    • Insert a flathead screwdriver into the top of the trim cover and gently pry it towards you.
    • Repeat the above step to the bottom of the trim cover.
    • Pull the trim cover off.
    • Set the trim cover aside in a safe place.
  2. How to Replace a Tail Light on a Nissan Pathfinder: 步骤 2 中的图像 1,3 How to Replace a Tail Light on a Nissan Pathfinder: 步骤 2 中的图像 2,3 How to Replace a Tail Light on a Nissan Pathfinder: 步骤 2 中的图像 3,3
    • Remove the two bolts using a 10mm socket and a 1/4" ratchet wrench.
    • Place the wrench on the top bolt and turn counterclockwise until the bolt is entirely off.
    • Repeat the above step to the bottom bolt.
    • Set bolts aside in a safe place.
  3. How to Replace a Tail Light on a Nissan Pathfinder: 步骤 3 中的图像 1,3 How to Replace a Tail Light on a Nissan Pathfinder: 步骤 3 中的图像 2,3 How to Replace a Tail Light on a Nissan Pathfinder: 步骤 3 中的图像 3,3
    • Gently pull on the tail light housing to disengage the friction fasteners from their grommets.
    • Once all fasteners have been disengaged, pull the tail light housing out.
  4. How to Replace a Tail Light on a Nissan Pathfinder: 步骤 4 中的图像 1,3 How to Replace a Tail Light on a Nissan Pathfinder: 步骤 4 中的图像 2,3 How to Replace a Tail Light on a Nissan Pathfinder: 步骤 4 中的图像 3,3
    • Rotate the grey plastic bulb socket 1/4 and turn counterclockwise before pulling it straight out of the housing.
    • Pull the old light bulb straight out of the socket.
  5. How to Replace a Tail Light on a Nissan Pathfinder: 步骤 5 中的图像 1,3 How to Replace a Tail Light on a Nissan Pathfinder: 步骤 5 中的图像 2,3 How to Replace a Tail Light on a Nissan Pathfinder: 步骤 5 中的图像 3,3
    • Push a new 7443 bulb into the socket.
    • Re-insert the socket into the housing and rotate it 1/4 turn clockwise to secure it in place.
  6. How to Replace a Tail Light on a Nissan Pathfinder: 步骤 6 中的图像 1,2 How to Replace a Tail Light on a Nissan Pathfinder: 步骤 6 中的图像 2,2
    • Line up the two metal pegs near the outer edge of the housing with their corresponding plastic grommets on the rear corner of the SUV.
    • Carefully push the tail light housing back into place.
  7. How to Replace a Tail Light on a Nissan Pathfinder: 步骤 7 中的图像 1,2 How to Replace a Tail Light on a Nissan Pathfinder: 步骤 7 中的图像 2,2
    • Spin in the two bolts a few turns by hand to prevent them from falling.
  8. How to Replace a Tail Light on a Nissan Pathfinder: 步骤 8 中的图像 1,2 How to Replace a Tail Light on a Nissan Pathfinder: 步骤 8 中的图像 2,2
    • Tighten the two bolts by turning them clockwise with the 10mm socket and a 1/4" drive ratchet until tight.
    • Avoid over-tightening the bolts to prevent from cracking the plastic inner edge of the tail light housing.
  9. How to Replace a Tail Light on a Nissan Pathfinder: 步骤 9 中的图像 1,3 How to Replace a Tail Light on a Nissan Pathfinder: 步骤 9 中的图像 2,3 How to Replace a Tail Light on a Nissan Pathfinder: 步骤 9 中的图像 3,3
    • Line up the trim cover and push it back into place over the inner edge of the tail light housing.
结论
另外一个人完成了本指南。
Leslie Salazar
于09/22/23注册
196 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 81
总计 1,148
