简介
If your door lock has finally succumbed to wear-and-tear or is no longer functioning the way it should, the steps in this guide will show you how to fully replace and install a new one.
A faulty door lock can lead to an unsafe environment and potentially cause harm to those occupying the property.
Before using this guide, ensure that the area around the lock and the door is clear of any debris that may interfere with the removal and installation of the new lock. Generally a small brush or cloth can be used to clear a small build up of dust or debris.
Additionally, make sure a cloth or container is placed below the door in case the lock falls off during installation to ensure no damage is done to the floor.
This fix should be relatively straight-forward and will take around 15-20 minutes to complete and won’t require any special skills.
Once you’ve cleared the area and have your tools ready, please proceed to step 1!
你所需要的
Place a piece of tape on both sides of the lock to ensure it doesn’t fall on the floor once unscrewed.
Ensure the surrounding area is free of any debris or dust that may interfere with the installation.
Place a towel, cloth, or even a container/bucket on the area below the door in case the lock falls to ensure no damage is done to the floor or the surrounding area.
Congratulations! You have successfully installed your new door lock!
另外一个人完成了本指南。
1指南评论
Hi Sanjeeve, this is a great guide its really helpful with the photos you have included here to really walk you through it. I am going to change my door lock to another type and found this article with other types of door locks helpful for that.
