跳转到主内容
How to Replace a Standard Door Lock
你所需要的
  1. How to Replace a Standard Door Lock, Standard Door Lock: 步骤 1 中的图像 1,2 How to Replace a Standard Door Lock, Standard Door Lock: 步骤 1 中的图像 2,2
    • Place a piece of tape on both sides of the lock to ensure it doesn’t fall on the floor once unscrewed.
    • Make sure enough tape is placed on the lock as the current door lock may be heavier than expected and could fall off once unscrewed.
    • Ensure the surrounding area is free of any debris or dust that may interfere with the installation.
    • Place a towel, cloth, or even a container/bucket on the area below the door in case the lock falls to ensure no damage is done to the floor or the surrounding area.
  2. How to Replace a Standard Door Lock: 步骤 2 中的图像 1,1
    • Use your Phillips #2 screwdriver to remove the two 70 mm pan head screws on the side that holds the lock in place.
    • Hold one side of the lock for extra stability if required.
  3. How to Replace a Standard Door Lock: 步骤 3 中的图像 1,2 How to Replace a Standard Door Lock: 步骤 3 中的图像 2,2
    • Remove the tape on both sides of the lock carefully.
  4. How to Replace a Standard Door Lock: 步骤 4 中的图像 1,3 How to Replace a Standard Door Lock: 步骤 4 中的图像 2,3 How to Replace a Standard Door Lock: 步骤 4 中的图像 3,3
    • Align your new lock with the given holes on the door.
  5. How to Replace a Standard Door Lock: 步骤 5 中的图像 1,2 How to Replace a Standard Door Lock: 步骤 5 中的图像 2,2
    • Place a piece of tape on both sides of the new lock to ensure the lock does not move when placing the screws.
    • Make sure the enough tape is placed on the lock as it may fall off depending on the weight of the door lock.
    • Place a cloth or container underneath the lock in case it falls off to ensure no damage is done to the floor or the surrounding area.
  6. How to Replace a Standard Door Lock: 步骤 6 中的图像 1,3 How to Replace a Standard Door Lock: 步骤 6 中的图像 2,3 How to Replace a Standard Door Lock: 步骤 6 中的图像 3,3
    • Place the 70 mm pan head screws in the given holes and use your Phillips #2 screwdriver to screw them in accordingly.
结论
Congratulations! You have successfully installed your new door lock!
另外一个人完成了本指南。
Sanjeeve Krishnamoorthy
于01/19/21注册
133 声望
撰写一个指南
团队
1指南评论
Hi Sanjeeve, this is a great guide its really helpful with the photos you have included here to really walk you through it. I am going to change my door lock to another type and found this article with other types of door locks helpful for that.
Terry - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 19
总计 999
