跳转到主内容
How to Replace a Screen Protector on an iPhone 12
你所需要的
  1. How to Replace a Screen Protector on an iPhone 12, Screen Protector: 步骤 1 中的图像 1,3 How to Replace a Screen Protector on an iPhone 12, Screen Protector: 步骤 1 中的图像 2,3 How to Replace a Screen Protector on an iPhone 12, Screen Protector: 步骤 1 中的图像 3,3
    • If you already have a pre-existing screen protector, you will gently peel of your existing screen protector from the top of you iPhone.
    • If any small pieces of the screen protector are still attached to the phone, genlty peel the pieces off until no more pieces remain.
    • When the screen protector and the pieces are removed, you can dispose of it immediately or set it aside for disposal.
  2. How to Replace a Screen Protector on an iPhone 12: 步骤 2 中的图像 1,3 How to Replace a Screen Protector on an iPhone 12: 步骤 2 中的图像 2,3 How to Replace a Screen Protector on an iPhone 12: 步骤 2 中的图像 3,3
    • Grab the wet cloth from the pack and wipe the screen of the iPhone in order to remove any stain or mark left behind.
  3. How to Replace a Screen Protector on an iPhone 12: 步骤 3 中的图像 1,2 How to Replace a Screen Protector on an iPhone 12: 步骤 3 中的图像 2,2
    • With the LCD cloth, wipe and dry the screen of the phone to remove any small debris or dust.
  4. How to Replace a Screen Protector on an iPhone 12: 步骤 4 中的图像 1,3 How to Replace a Screen Protector on an iPhone 12: 步骤 4 中的图像 2,3 How to Replace a Screen Protector on an iPhone 12: 步骤 4 中的图像 3,3
    • Grab the dust sticker and apply it all around on the screen multiple times, until you covered all areas of the iPhone display.
  5. How to Replace a Screen Protector on an iPhone 12: 步骤 5 中的图像 1,3 How to Replace a Screen Protector on an iPhone 12: 步骤 5 中的图像 2,3 How to Replace a Screen Protector on an iPhone 12: 步骤 5 中的图像 3,3
    • Grab the screen protector and remove the plastic that's attached to the sticky part of the screen protector.
    • Align the new screen protector to the iPhone without touching the sticky part.
    • Press down on the screen protector from the top of the iPhone until you reach the bottom.
  6. How to Replace a Screen Protector on an iPhone 12: 步骤 6 中的图像 1,3 How to Replace a Screen Protector on an iPhone 12: 步骤 6 中的图像 2,3 How to Replace a Screen Protector on an iPhone 12: 步骤 6 中的图像 3,3
    • With the new screen protector on the phone, use the anti-bubble card to prevent bubbles from staying in between the iPhone and the screen protector.
    • Push the bubbles towards the edge of the iPhone until you see no more on the screen.
  7. How to Replace a Screen Protector on an iPhone 12: 步骤 7 中的图像 1,1
    • With the bubbles removed from the screen, the new screen protector for the iPhone 12 is now installed.
    • Dispose of any waste left after the installation.
结论
另外一个人完成了本指南。
reveleszacatecas5
于10/24/23注册
169 声望
撰写一个指南
团队
CSU Los Angeles, Team 8-3, Ribeiro Fall 2023 CSU Los Angeles, Team 8-3, Ribeiro Fall 2023 的会员
CSULA-RIBEIRO-F23S8G3
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 54
过去 30 天: 229
总计 5,231
