跳转到主内容
How to Replace a RG-6 Coaxial Cable Connector
你所需要的
  1. How to Replace a RG-6 Coaxial Cable Connector, RG-6 Coaxial Cable Connector: 步骤 1 中的图像 1,2 How to Replace a RG-6 Coaxial Cable Connector, RG-6 Coaxial Cable Connector: 步骤 1 中的图像 2,2
    • Use a cable cutter to cut your desired length of cable.
    • Cut both ends of the cable at 90 degrees, meaning the cutter and the cable should be positioned at 90 degree of one another.
  2. How to Replace a RG-6 Coaxial Cable Connector: 步骤 2 中的图像 1,3 How to Replace a RG-6 Coaxial Cable Connector: 步骤 2 中的图像 2,3 How to Replace a RG-6 Coaxial Cable Connector: 步骤 2 中的图像 3,3
    • Use a RG-6 coaxial cable stripper to strip each end of the cable.
    • Position the end of cable inside the stripper and rotate it around the cable in a clockwise motion three times. Then, do one full turn counterclockwise.
    • Repeat this on the other end of the cable.
    • After stripping the ends, remove the two pieces of shield cable from the cable.
  3. How to Replace a RG-6 Coaxial Cable Connector: 步骤 3 中的图像 1,3 How to Replace a RG-6 Coaxial Cable Connector: 步骤 3 中的图像 2,3 How to Replace a RG-6 Coaxial Cable Connector: 步骤 3 中的图像 3,3
    • Using your fingers, fan the internal wires out.
    • Mold the braided wires into a flower shape.
    • Remove any excess braid from the core side of the cable (the gold color part).
  4. How to Replace a RG-6 Coaxial Cable Connector: 步骤 4 中的图像 1,3 How to Replace a RG-6 Coaxial Cable Connector: 步骤 4 中的图像 2,3 How to Replace a RG-6 Coaxial Cable Connector: 步骤 4 中的图像 3,3
    • Insert the cable into the thin part of the RG-6 connector.
    • Gently push the cable into the connector. Do not bend or fold the gold portion of the cable.
    • Make sure that the cable's insulator (white portion) and the inside of the connector are flush.
  5. How to Replace a RG-6 Coaxial Cable Connector: 步骤 5 中的图像 1,3 How to Replace a RG-6 Coaxial Cable Connector: 步骤 5 中的图像 2,3 How to Replace a RG-6 Coaxial Cable Connector: 步骤 5 中的图像 3,3
    • To crimp the end of the cable, place one end of the cable into the cable slot of the crimper.
    • Insert one cable end into the appropriate slot for the connector in the crimper.
    • With your thumb, hold down the cable so it will not come out of the cable slot.
  6. How to Replace a RG-6 Coaxial Cable Connector: 步骤 6 中的图像 1,1
    • To crimp the connector to the cable, gently pull down the crimper's lever.
    • There is no need to do it multiple times.
    • Secure the connector to both ends of the cable.
  7. How to Replace a RG-6 Coaxial Cable Connector: 步骤 7 中的图像 1,3 How to Replace a RG-6 Coaxial Cable Connector: 步骤 7 中的图像 2,3 How to Replace a RG-6 Coaxial Cable Connector: 步骤 7 中的图像 3,3
    • Check that there is no braid hanging outside of the connector.
    • Loose braids can cause problems with signals.
    • Check that the cables insulation is flush with the connector.
    • If there is loose braid, you'll have to start over from Step 1.
结论
Vic
于10/26/22注册
145 声望
撰写一个指南
团队
CSU Los Angeles, Team 1-66, Briggs Fall 2022 CSU Los Angeles, Team 1-66, Briggs Fall 2022 的会员
CSULA-BRIGGS-F22S1G66
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 43
过去 30 天: 188
总计 3,383
