跳转到主内容
How to Replace a Nequare Cordless Vacuum S182 Filter
  1. How to Replace a Nequare Cordless Vacuum S182 Filter, Filter: 步骤 1 中的图像 1,2 How to Replace a Nequare Cordless Vacuum S182 Filter, Filter: 步骤 1 中的图像 2,2
    • Locate the black button to release the white motor unit from the rest of the vacuum cleaner.
  2. How to Replace a Nequare Cordless Vacuum S182 Filter: 步骤 2 中的图像 1,2 How to Replace a Nequare Cordless Vacuum S182 Filter: 步骤 2 中的图像 2,2
    • Hold down the black button to remove the white motor unit above and gently pull the motor unit upwards.
  3. How to Replace a Nequare Cordless Vacuum S182 Filter: 步骤 3 中的图像 1,2 How to Replace a Nequare Cordless Vacuum S182 Filter: 步骤 3 中的图像 2,2
    • Press the release button at the side of the dust canister to dispose of the debris.
    • Be sure to hold the the canister over a garbage can to avoid a spill.
  4. How to Replace a Nequare Cordless Vacuum S182 Filter: 步骤 4 中的图像 1,3 How to Replace a Nequare Cordless Vacuum S182 Filter: 步骤 4 中的图像 2,3 How to Replace a Nequare Cordless Vacuum S182 Filter: 步骤 4 中的图像 3,3
    • After emptying the debris, hold down the black button, then twist and pull the canister out.
  5. How to Replace a Nequare Cordless Vacuum S182 Filter: 步骤 5 中的图像 1,2 How to Replace a Nequare Cordless Vacuum S182 Filter: 步骤 5 中的图像 2,2
    • Take the filter out and dispose of it.
  6. How to Replace a Nequare Cordless Vacuum S182 Filter: 步骤 6 中的图像 1,2 How to Replace a Nequare Cordless Vacuum S182 Filter: 步骤 6 中的图像 2,2
    • Remove the black part by gently pushing from inside of the canister.
  7. How to Replace a Nequare Cordless Vacuum S182 Filter: 步骤 7 中的图像 1,2 How to Replace a Nequare Cordless Vacuum S182 Filter: 步骤 7 中的图像 2,2
    • Clean both the canister and the black part either by rinsing it out or using a wash cloth.
  8. How to Replace a Nequare Cordless Vacuum S182 Filter: 步骤 8 中的图像 1,3 How to Replace a Nequare Cordless Vacuum S182 Filter: 步骤 8 中的图像 2,3 How to Replace a Nequare Cordless Vacuum S182 Filter: 步骤 8 中的图像 3,3
    • Put the black part back into the canister and put in the new filter.
结论
另外一个人完成了本指南。
Oghenefejiro Egede
于01/26/21注册
181 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 36
总计 1,338
