跳转到主内容
How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock
你所需要的
  1. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock, Door Lock: 步骤 1 中的图像 1,3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock, Door Lock: 步骤 1 中的图像 2,3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock, Door Lock: 步骤 1 中的图像 3,3
    • Unscrew the lockbolt of the old door and remove it.
  2. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 2 中的图像 1,2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 2 中的图像 2,2
    • Match the adapter to a position where it fits into the middle hole of the door’s lock spot.
  3. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 3 中的图像 1,2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 3 中的图像 2,2
    • Attach the two door mounting plates together, aligning the holes between the two plates.
  4. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 4 中的图像 1,2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 4 中的图像 2,2
    • Once attached together, flip it the other way and attach it to the lock spot.
  5. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 5 中的图像 1,3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 5 中的图像 2,3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 5 中的图像 3,3
    • Screw the screws back in.
  6. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 6 中的图像 1,3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 6 中的图像 2,3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 6 中的图像 3,3
    • Flip your August Smart Lock (4 Gen.) so that the back faces the door.
    • Make sure that both of its side wing latches are still open.
  7. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 7 中的图像 1,3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 7 中的图像 2,3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 7 中的图像 3,3
    • Attach the lock to the mounting plates, matching it in the center of the adapter’s tailpiece shape to see how it fits.
    • This may take some rotating to see how it can fit on best.
  8. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 8 中的图像 1,2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 8 中的图像 2,2
    • Once fit, proceed to close both of the open wing latches on the smart lock.
  9. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 9 中的图像 1,3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 9 中的图像 2,3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 9 中的图像 3,3
    • Gently push on the ‘August’ logo on the front cover of the electronic lock to lift the front cover (the magnetic buckle).
    • Here, you will find the batteries’ placement area.
  10. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 10 中的图像 1,3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 10 中的图像 2,3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 10 中的图像 3,3
    • If sealed, remove/tear off the plastic seal, then put the given lithium batteries in their designated area.
    • Make sure to place them the right side up - keep in mind that the negative attracts the positive.
  11. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 11 中的图像 1,2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 11 中的图像 2,2
    • After doing so, you’ll see the ‘August’ Smart Lock flash a green light.
    • Once that happens, put the front cover back on.
  12. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 12 中的图像 1,2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 12 中的图像 2,2
    • Download and configure the August Smart Lock application on your cellular device.
    • Follow the on-screen instructions to connect to your lock.
    • Pay attention to the light coming from the logo as you proceed.
  13. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 13 中的图像 1,2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 13 中的图像 2,2
    • Once done, test the application by pressing your phone screen to lock your door.
  14. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 14 中的图像 1,2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 14 中的图像 2,2
    • Test the application again by pressing your phone screen to unlock your door this time.
  15. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 15 中的图像 1,2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: 步骤 15 中的图像 2,2
    • Your new Wi-Fi controlled smart lock should now be ready to use at any time.
结论
Don’t forget to change the lock’s batteries regularly to avoid locking you or anyone else out by accident.
You can learn more information on installing the August Smart Lock at https://www.acslocks.com/how-to-install-....
团队
York University, Team M-2, Allen Summer 2023 York University, Team M-2, Allen Summer 2023 的会员
YORK-ALLEN-SU23SMG2
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 19
总计 227
