跳转到主内容
How to Replace a Jeans Zipper with Buttons
你所需要的
  1. How to Replace a Jeans Zipper with Buttons, Zipper: 步骤 1 中的图像 1,3 How to Replace a Jeans Zipper with Buttons, Zipper: 步骤 1 中的图像 2,3 How to Replace a Jeans Zipper with Buttons, Zipper: 步骤 1 中的图像 3,3
    • Open the broken zipper and identify the stitches.
    • Take the seam ripper and insert it under the last stitch seen.
    • Remove the stitches of the zipper and when most are removed, cut the rest of the zipper with fabric scissors.
    • Make sure to remove at least one half of the zipper.
  2. How to Replace a Jeans Zipper with Buttons: 步骤 2 中的图像 1,2 How to Replace a Jeans Zipper with Buttons: 步骤 2 中的图像 2,2
    • Insert the buttons tack to the right fly of the jeans.
    • Insert 2 or 3 button tacks, depending on the length of the fly.
    • Add textile glue to the pointed part of the tacks.
    • Adding glue to the tacks helps secure the buttons and avoids damage caused by the washing machine and daily use.
  3. How to Replace a Jeans Zipper with Buttons: 步骤 3 中的图像 1,1
    • While the textile glue is fresh, insert the buttons into the tacks and make sure they are secure.
    • You will notice the buttons are secure after you hear a clicking noise when pressing the buttons to the tacks.
  4. How to Replace a Jeans Zipper with Buttons: 步骤 4 中的图像 1,1
    • Cut three holes using the pointed part of the fabric scissor on the left fly of the jeans that correspond with the buttons on the right.
    • Make sure to open the fabric scissor and use only one blade.
    • Alternatively if you have access to a sewing machine, follow this guide to create the button holes.
  5. How to Replace a Jeans Zipper with Buttons: 步骤 5 中的图像 1,1
    • Using a needle and some thread, stitch the edges of the button holes to finish them.
  6. How to Replace a Jeans Zipper with Buttons: 步骤 6 中的图像 1,1
    • Make sure the buttons are secure, that they fit the holes, and that they open and close easily.
结论
At the end of the guide, you will have a pair of jeans that close with a set of buttons instead of a zipper.
1指南评论
How do I fix zip on medical scrubs top
Adom Asare - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 63
总计 5,635
