跳转到主内容
How to Replace a Guess W0016L2 Watch Battery
你所需要的
  1. How to Replace a Guess W0016L2 Watch Battery, Watch Battery: 步骤 1 中的图像 1,3 How to Replace a Guess W0016L2 Watch Battery, Watch Battery: 步骤 1 中的图像 2,3 How to Replace a Guess W0016L2 Watch Battery, Watch Battery: 步骤 1 中的图像 3,3
    • Press the buttons on the sides of the watch clasp to release the latch.
    • Open the watch clasp.
  2. How to Replace a Guess W0016L2 Watch Battery: 步骤 2 中的图像 1,3 How to Replace a Guess W0016L2 Watch Battery: 步骤 2 中的图像 2,3 How to Replace a Guess W0016L2 Watch Battery: 步骤 2 中的图像 3,3
    • Place the watch on its side.
    • Use a pin tool to push the clasp pin out from the side and remove it.
  3. How to Replace a Guess W0016L2 Watch Battery: 步骤 3 中的图像 1,3 How to Replace a Guess W0016L2 Watch Battery: 步骤 3 中的图像 2,3 How to Replace a Guess W0016L2 Watch Battery: 步骤 3 中的图像 3,3
    • Align the tip of the huaxing tool with the notches on the back case of the watch.
    • Once the huaxing tool is aligned with the notches on the back of the watch, turn it counterclockwise to unscrew the back case.
  4. How to Replace a Guess W0016L2 Watch Battery: 步骤 4 中的图像 1,2 How to Replace a Guess W0016L2 Watch Battery: 步骤 4 中的图像 2,2
    • Use tweezers or a spudger to remove the plastic guard covering the battery.
  5. How to Replace a Guess W0016L2 Watch Battery: 步骤 5 中的图像 1,3 How to Replace a Guess W0016L2 Watch Battery: 步骤 5 中的图像 2,3 How to Replace a Guess W0016L2 Watch Battery: 步骤 5 中的图像 3,3
    • Use a spudger to gently lift the battery clip just enough to slide the battery out from the holder.
    • If you're using tweezers, simply remove the battery.
  6. How to Replace a Guess W0016L2 Watch Battery: 步骤 6 中的图像 1,3 How to Replace a Guess W0016L2 Watch Battery: 步骤 6 中的图像 2,3 How to Replace a Guess W0016L2 Watch Battery: 步骤 6 中的图像 3,3
    • Use tweezers or your hands to place the new battery into the battery slot with the positive side facing upwards.
  7. How to Replace a Guess W0016L2 Watch Battery: 步骤 7 中的图像 1,2 How to Replace a Guess W0016L2 Watch Battery: 步骤 7 中的图像 2,2
    • Set the plastic guard back in place by aligning it with the stems of the crown.
  8. How to Replace a Guess W0016L2 Watch Battery: 步骤 8 中的图像 1,3 How to Replace a Guess W0016L2 Watch Battery: 步骤 8 中的图像 2,3 How to Replace a Guess W0016L2 Watch Battery: 步骤 8 中的图像 3,3
    • Replace the back case of the watch.
    • Align the watch case opener with the notches on the back case and turn it clockwise to tighten.
  9. How to Replace a Guess W0016L2 Watch Battery: 步骤 9 中的图像 1,3 How to Replace a Guess W0016L2 Watch Battery: 步骤 9 中的图像 2,3 How to Replace a Guess W0016L2 Watch Battery: 步骤 9 中的图像 3,3
    • Insert the pin into the watch link.
    • Slide the pin into one of the holes of the clasp.
    • Push the pin down and place it under the second hole of the clasp.
终点
另外一个人完成了本指南。
Hassaan Bashir
于01/31/25注册
199 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 36
总计 364
