简介
The following replacement guide explains how to replace your Gigabyte Geforce RTX 2060 graphics card with any other GPU of your choice.
Every computer needs a graphics card to properly function. The graphics card is what is used to render the things you see on screen, so whether your current GPU is defective/damaged or even outdated, this guide will help you get your computer working properly again.
Prior to beginning the guide, be sure to power down your device and disconnect from the power chord. Additionally, work on a hard surface and avoid working on a carpeted area.
你所需要的
Shut down and unplug everything from the back of your PC.
Flip the power supply switch so that it is OFF.
Take off the side panel by removing the screws that lock it in place.
To reassemble your device, follow steps 1-3 in reverse order.
5等其他人完成本指南。
