跳转到主内容
加入维修社区 - 创建账户
How to Replace a Damaged Gutter Segment
你所需要的
    1. How to Replace a Damaged Gutter Segment, Eavestrough Gutter Segment: 步骤 1 中的图像 1,1
      • Identify the section of the gutter system that needs to be replaced, specifically the middle gutter.
      询问修复机器人
      添加评论
    2. How to Replace a Damaged Gutter Segment: 步骤 2 中的图像 1,2 How to Replace a Damaged Gutter Segment: 步骤 2 中的图像 2,2
      • Using a screwdriver, remove the screws from the strip that holds the gutter to the wall.
      • Repeat this process for each strip along the length of the gutter.
      • Spread apart the strips to release the gutter.
      • When spreading apart the strips, they may have sharp edges. To ensure your safety, please use caution and wear protective gloves.
      询问修复机器人
      添加评论
    3. How to Replace a Damaged Gutter Segment: 步骤 3 中的图像 1,3 How to Replace a Damaged Gutter Segment: 步骤 3 中的图像 2,3 How to Replace a Damaged Gutter Segment: 步骤 3 中的图像 3,3
      • Locate the connecting points between the bottom gutter and the middle gutter.
      • Using a screwdriver, remove the screws.
      • Separate the bottom gutter from the middle gutter by sliding them apart.
      询问修复机器人
      添加评论
    4. How to Replace a Damaged Gutter Segment: 步骤 4 中的图像 1,3 How to Replace a Damaged Gutter Segment: 步骤 4 中的图像 2,3 How to Replace a Damaged Gutter Segment: 步骤 4 中的图像 3,3
      • Detach the top gutter from the connected fittings.
      • Position yourself securely on a ladder or elevated platform at the appropriate height to access the top gutter.
      • Place the removed top gutter and the middle gutter on the ground.
      • Inspect both the top gutter and the middle gutter for any damage. Assess whether they need to be entirely replaced or if repairs can be made.
      • If the damaged area is serious, you can only replace with a new segment (looking for environmentally friendly materials to protect the earth).
      询问修复机器人
      添加评论
    5. How to Replace a Damaged Gutter Segment: 步骤 5 中的图像 1,3 How to Replace a Damaged Gutter Segment: 步骤 5 中的图像 2,3 How to Replace a Damaged Gutter Segment: 步骤 5 中的图像 3,3
      • Slide the new middle gutter into the top gutter, inserting it gently until they are firmly connected.
      • Double-check that the alignment is correct and there are no gaps between the sections to avoid any drainage.
      • With the middle and top gutters connected, reattach the assembled gutters to the connected fittings.
      询问修复机器人
      添加评论
    6. How to Replace a Damaged Gutter Segment: 步骤 6 中的图像 1,3 How to Replace a Damaged Gutter Segment: 步骤 6 中的图像 2,3 How to Replace a Damaged Gutter Segment: 步骤 6 中的图像 3,3
      • Load a screw into the strip, positioning it so that it can be screwed into the holes of both the strip and the gutter.
      • Fold the strip around the gutter, aligning the holes of the strip with the corresponding holes on the gutter.
      • Screw the screws into the holes of the strip and the gutter, using a screwdriver.
      • Repeat this process for each strip along the length of the new middle gutter.
      • Take care not to overtighten the screw, as it may damage the gutter or strip the threads.
      询问修复机器人
      添加评论
    7. How to Replace a Damaged Gutter Segment: 步骤 7 中的图像 1,3 How to Replace a Damaged Gutter Segment: 步骤 7 中的图像 2,3 How to Replace a Damaged Gutter Segment: 步骤 7 中的图像 3,3
      • Position the bottom gutter in its intended location, ensuring that the holes on both pieces line up properly.
      • Using a screwdriver, tighten the screws to fasten the middle and bottom gutters together.
      • Replacement Complete!
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
2等其他人完成本指南。
Gavin Luc
于10/19/22注册
163 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 36
过去 30 天: 179
总计 3,414
