简介
In this guide, we will provide step-by-step instructions for replacing a gutter. Whether you are dealing with a damaged gutter or simply upgrading to a new one, this guide will help you through the process.
Gutter replacements performed by professionals can often come with a hefty price tag. By following this guide, you can save money and gain the satisfaction of completing the task on your own.
Most importantly, damage to the gutter could potentially cause various issues in the drainage system. By following this guide, you can successfully replace your gutter and ensure its proper installation for effective water drainage and maintenance of your property.
你所需要的
Identify the section of the gutter system that needs to be replaced, specifically the middle gutter.
Detach the top gutter from the connected fittings.
Place the removed top gutter and the middle gutter on the ground.
Inspect both the top gutter and the middle gutter for any damage. Assess whether they need to be entirely replaced or if repairs can be made.
If the damaged area is serious, you can only replace with a new segment (looking for environmentally friendly materials to protect the earth).
Load a screw into the strip, positioning it so that it can be screwed into the holes of both the strip and the gutter.
Fold the strip around the gutter, aligning the holes of the strip with the corresponding holes on the gutter.
Screw the screws into the holes of the strip and the gutter, using a screwdriver.
Repeat this process for each strip along the length of the new middle gutter.
