跳转到主内容
加入维修社区 - 创建账户
How to Replace a Corroded Car Battery Terminal
你所需要的
  1. How to Replace a Corroded Car Battery Terminal, Car Battery Terminal: 步骤 1 中的图像 1,2 How to Replace a Corroded Car Battery Terminal, Car Battery Terminal: 步骤 1 中的图像 2,2
    • Remember to remove your car key from the ignition and shut off the car before performing this guide.
    • Locate the terminals on the top of the car battery. Next to each terminal is a positive(+) or negative(-) sign, indicating the charge.
    • The positive terminal looks to be in working order, but the negative end has a lot of corrosion buildup. This terminal needs to be replaced.
    询问修复机器人
    添加评论
  2. How to Replace a Corroded Car Battery Terminal: 步骤 2 中的图像 1,2 How to Replace a Corroded Car Battery Terminal: 步骤 2 中的图像 2,2
    • Find the nut located on the side of the terminal.
    • Using an adjustable wrench, rotate the nut counterclockwise to loosen it.
    • Use an appropriately-sized wrench or socket, not channel locks as shown in the photo.
    • You do not need to loosen the nut all the way off the bolt, but just enough to loosen the terminal's grip on the node.
    询问修复机器人
    添加评论
  3. How to Replace a Corroded Car Battery Terminal: 步骤 3 中的图像 1,2 How to Replace a Corroded Car Battery Terminal: 步骤 3 中的图像 2,2
    • Always remember to remove the negative terminal first before the positive terminal. This will prevent shorting to the ground and possibly causing shock or a fire.
    • Carefully use a rag to lift up the terminal off of the battery node.
    • Be cautious when handling battery corrosion, as it can irritate the skin and is harmful if it comes in contact with your eyes.
    • Place the terminal on a rag or towel and make sure it doesn't come in contact with the battery node.
    添加评论
  4. How to Replace a Corroded Car Battery Terminal: 步骤 4 中的图像 1,2 How to Replace a Corroded Car Battery Terminal: 步骤 4 中的图像 2,2
    • On the positive terminal, locate the nut along the side.
    • Using the wrench, rotate the nut counterclockwise.
    • You do not need to fully loosen the nut off the bolt, but just enough for the terminal to be easily removed from the node.
    询问修复机器人
    添加评论
  5. How to Replace a Corroded Car Battery Terminal: 步骤 5 中的图像 1,2 How to Replace a Corroded Car Battery Terminal: 步骤 5 中的图像 2,2
    • Using a rag, carefully remove the positive terminal from the battery node.
    • Place the terminal on a rag or towel, and make sure it does not come into contact with the battery node.
    添加评论
  6. How to Replace a Corroded Car Battery Terminal: 步骤 6 中的图像 1,3 How to Replace a Corroded Car Battery Terminal: 步骤 6 中的图像 2,3 How to Replace a Corroded Car Battery Terminal: 步骤 6 中的图像 3,3
    • On the negative terminal, locate the nut on the side facing upwards.
    • Using the wrench, rotate the nut counterclockwise and remove it from the bolt.
    询问修复机器人
    添加评论
  7. How to Replace a Corroded Car Battery Terminal: 步骤 7 中的图像 1,3 How to Replace a Corroded Car Battery Terminal: 步骤 7 中的图像 2,3 How to Replace a Corroded Car Battery Terminal: 步骤 7 中的图像 3,3
    • Take the wire plate on top and remove it carefully from the bolt.
    • At this point, it is fine to handle the metal plate with your hands since the terminals are disconnected from the battery and there is nothing completing the circuit.
    • Remove the bottom wire plate from the bolt, placing it carefully to the side.
    询问修复机器人
    添加评论
  8. How to Replace a Corroded Car Battery Terminal: 步骤 8 中的图像 1,2 How to Replace a Corroded Car Battery Terminal: 步骤 8 中的图像 2,2
    • Set aside the old battery terminal, and replace it with the new one.
    • Replace the wire plates in the order they were taken off.
    • Although it is not necessary that the plates be placed in the same order again, it is generally a good idea to go with the order that it came in.
    添加评论
  9. How to Replace a Corroded Car Battery Terminal: 步骤 9 中的图像 1,2 How to Replace a Corroded Car Battery Terminal: 步骤 9 中的图像 2,2
    • Place the flat washer and the screw-on head that came with the battery terminal onto the vertical bolt.
    • Tighten the head clockwise and make sure the wire plates are secured.
    • Not all battery terminal packs come with a washer and screw-on head. If your pack comes with a nut, use the wrench and tighten the bolt clockwise.
    询问修复机器人
    添加评论
  10. How to Replace a Corroded Car Battery Terminal: 步骤 10 中的图像 1,1
    • Using a rag, place the positive terminal back onto the positive node.
    询问修复机器人
    添加评论
  11. How to Replace a Corroded Car Battery Terminal: 步骤 11 中的图像 1,1
    • Place the negative terminal back onto the negative node.
    询问修复机器人
    添加评论
  12. How to Replace a Corroded Car Battery Terminal: 步骤 12 中的图像 1,3 How to Replace a Corroded Car Battery Terminal: 步骤 12 中的图像 2,3 How to Replace a Corroded Car Battery Terminal: 步骤 12 中的图像 3,3
    • On the negative terminal, use the wrench to rotate the side nut clockwise to tighten it.
    • Next, perform the same action on the side nut of the positive terminal.
    • To ensure a secure connection, be sure the nut is snug and that the terminal can't come off easily.
    添加评论
终点
取消:我没有完成这个指南。
22等其他人完成本指南。
David Wright
于02/23/15注册
775 声望
撰写一个指南
团队
Cal Poly, Team 12-4, Green Winter 2015 Cal Poly, Team 12-4, Green Winter 2015 的会员
CPSU-GREEN-W15S12G4
5 名成员
创作了10篇指南
8指南评论
Nice post. Shop car battery at batterybhai and their expert technical team come to install the battery with all battery replacement tools kit.
mayank tanwar - 回复 分享
very interesting post. Thanks for sharing it.
https://www.sarexports.com/product-categ...
Raman Malik - 回复 分享
I change negative terminal to new one still have corrosion why?
אנדריי מזילו - 回复 分享
They are corrotion after doinging this within a4 to 5 month time the red cable is worst
Carol - 回复 分享
Use Petroleum-Jelly (preferably) OR if not there then
use Vaseline onto both the Terminals( +, -ive) to prevent rusting of your both terminals of Battery PLEASE .
SANJAY KHANDELWAL - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 138
过去 30 天: 704
总计 149,409
