跳转到主内容
Whirlpool Refrigerator Start Relay Assembly Replacement
你所需要的
  1. Whirlpool Refrigerator Start Relay Assembly Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: 步骤 2 中的图像 1,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: 步骤 2 中的图像 2,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: 步骤 2 中的图像 3,3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: 步骤 3 中的图像 1,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: 步骤 3 中的图像 2,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: 步骤 3 中的图像 3,3
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: 步骤 4 中的图像 1,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: 步骤 4 中的图像 2,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: 步骤 4 中的图像 3,3
    • Use a flathead screwdriver, or a similar tool, to disconnect any connectors attached to the start relay assembly.
  5. Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: 步骤 5 中的图像 1,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: 步骤 5 中的图像 2,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: 步骤 5 中的图像 3,3
    • Pull the metal clip out its hole in the top of the start relay assembly.
    • Rest the clip next to the assembly.
  6. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: 步骤 6 中的图像 1,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: 步骤 6 中的图像 2,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: 步骤 6 中的图像 3,3
    • Pull the start relay assembly straight off its prongs in the chassis.
    • Remove the start relay assembly.
    • The assembly consists of the start capacitor, start relay, and overload relay.
  7. Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: 步骤 7 中的图像 1,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: 步骤 7 中的图像 2,3 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: 步骤 7 中的图像 3,3
    • If you own a multimeter, you can test the start relay and overload relay's resistance.
    • A range between 0–1 Ω for the overload relay, and 0–5 Ω for the start relay is acceptable.
结论
Repair didn’t go as planned? Ask our Answers community for help.
4等其他人完成本指南。
nicO
于04/14/15注册
15,885 声望
创作了88篇指南
团队
Global Fixers Global Fixers 的会员
Community
32 名成员
创作了531篇指南
2条评论
While the parts are similar, there are differences for fridges. If you can find your refrigerator model number, you'll be able to search online for the correct start relay for your specific model. Good luck!
nicO -
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 62
过去 30 天: 318
总计 7,670
