跳转到主内容
How to Replace a Coffee Tabletop Glass
你所需要的
  1. How to Replace a Coffee Tabletop Glass, Coffee Table Glass: 步骤 1 中的图像 1,2 How to Replace a Coffee Tabletop Glass, Coffee Table Glass: 步骤 1 中的图像 2,2
    • Flip the coffee table base upside down on an empty area.
  2. How to Replace a Coffee Tabletop Glass: 步骤 2 中的图像 1,1
    • Use a cleaning spray to clean the surface of the glass table.
    • Use gloves while cleaning the table. The glass cleaner spray may contain toxic chemicals.
  3. How to Replace a Coffee Tabletop Glass: 步骤 3 中的图像 1,2 How to Replace a Coffee Tabletop Glass: 步骤 3 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove one 1/4 in.-20 x 1-1/2 in. socket cap screw from the side of the glass.
    • Repeat the process for the other 1/4 in.-20 x 1-1/2 in. socket cap screw.
    • The appearance of this screw may differ from table to table, but the procedure remains the same. Use the appropriate screwdriver to open the screws.
  4. How to Replace a Coffee Tabletop Glass: 步骤 4 中的图像 1,2 How to Replace a Coffee Tabletop Glass: 步骤 4 中的图像 2,2
    • Remove the coffee table legs piece by piece.
  5. How to Replace a Coffee Tabletop Glass: 步骤 5 中的图像 1,1
    • Remove the glass.
    • Remember that glass can be shattered or partially damaged. Use gloves to avoid possible cuts.
  6. How to Replace a Coffee Tabletop Glass: 步骤 6 中的图像 1,1
    • Replace the broken/ damaged glass with the new one.
结论
Jasrin Kaur
于05/10/21注册
133 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 40
总计 3,321
