简介
Need to remove or replace an old cabinet door? Here's an easy step by step guide on removing and replacing a cabinet door using only a screwdriver.
你所需要的
Using a screwdriver, either a Flathead or a Phillips, remove the screws starting from the bottom of the door all the way to the top of the door to prevent the door from swinging.
即将完成!
To reassemble your cabinet, follow these instructions in reverse order.
结论
另外一个人完成了本指南。
