跳转到主内容
How to Replace a Button on a Shirt
你所需要的
  1. How to Replace a Button on a Shirt, How to Replace a Button on a Shirt: 步骤 1 中的图像 1,3 How to Replace a Button on a Shirt, How to Replace a Button on a Shirt: 步骤 1 中的图像 2,3 How to Replace a Button on a Shirt, How to Replace a Button on a Shirt: 步骤 1 中的图像 3,3
    • Lay both shirts down on a clean flat surface.
    • Identify your old shirt.
    • Use your sewing scissors to cut a button from the old shirt, (preferably from an area that won't be noticeable). The bottom of the shirt is a great place to start, as most shirts have an extra button sewn-on, in the event that a button is popped or lost.
    • Set your newly cut button aside.
  2. How to Replace a Button on a Shirt: 步骤 2 中的图像 1,2 How to Replace a Button on a Shirt: 步骤 2 中的图像 2,2
    • Pick up both your needle, and the selected thread, that you will use to make repairs.
    • This may take a bit of time, as threading a needle can be quite tricky. Take the thread, and place it through the opening at the top of your needle.
    • Once you have placed the thread in the needle, create a knot on the end.
    • If you are struggling to thread the needle, or need a video example, check out this video.
  3. How to Replace a Button on a Shirt: 步骤 4 中的图像 1,3 How to Replace a Button on a Shirt: 步骤 4 中的图像 2,3 How to Replace a Button on a Shirt: 步骤 4 中的图像 3,3
    • Now, grab your threaded needle and the shirt that you wish to repair.
    • While not required, this would be a great time to place your thimble on your finger, if you elected to purchase one.
    • Flip up the collar, so that the underside of the collar is facing you.
    • Insert the needle into the button-hole area, where the missing button was located.
    • Pull the thread through to the end until the knot stops it.
  4. How to Replace a Button on a Shirt: 步骤 5 中的图像 1,3 How to Replace a Button on a Shirt: 步骤 5 中的图像 2,3 How to Replace a Button on a Shirt: 步骤 5 中的图像 3,3
    • After you've made your first stitch into the shirt, take the recycled button and put the needle through the bottom of one of the holes.
    • This will bring the button onto the thread.
    • Next, thread through the second button to secure, and pull down, so that the button now rests in the area of the missing button.
  5. How to Replace a Button on a Shirt: 步骤 6 中的图像 1,3 How to Replace a Button on a Shirt: 步骤 6 中的图像 2,3 How to Replace a Button on a Shirt: 步骤 6 中的图像 3,3
    • After you have secured the button to the front of the shirt, time to secure it through the back.
    • Take your needle and thread, and insert from the back of the shirt, into the buttons (both top and bottom).
    • Secure the button, so that it is sewn from the front and back.
  6. How to Replace a Button on a Shirt: 步骤 7 中的图像 1,3 How to Replace a Button on a Shirt: 步骤 7 中的图像 2,3 How to Replace a Button on a Shirt: 步骤 7 中的图像 3,3
    • When the needle is on the other side, go through one of the button's holes again. This step can be repeated as one may like to achieve the desired look for the button.
    • You control how secured you wish to have the button, and its design.
  7. How to Replace a Button on a Shirt: 步骤 8 中的图像 1,3 How to Replace a Button on a Shirt: 步骤 8 中的图像 2,3 How to Replace a Button on a Shirt: 步骤 8 中的图像 3,3
    • After you are done adjusting the button, go through the other side of the shirt again.
    • Then, rotate the thread around the button a minimum of three times. This will lock the button in behind the thread.
  8. How to Replace a Button on a Shirt: 步骤 9 中的图像 1,3 How to Replace a Button on a Shirt: 步骤 9 中的图像 2,3 How to Replace a Button on a Shirt: 步骤 9 中的图像 3,3
    • As an added layer of security, if you want, you can secure the button to a piece of fabric, to eliminate any movement.
    • Take a small piece of fabric behind the button area, and sewn-in the button holes, into the fabric.
    • After making sure it is tight, grab the needle and put it in between the two threads to create a knot.
  9. How to Replace a Button on a Shirt: 步骤 10 中的图像 1,3 How to Replace a Button on a Shirt: 步骤 10 中的图像 2,3 How to Replace a Button on a Shirt: 步骤 10 中的图像 3,3
    • The knot should look like the first picture.
    • Cut the extra thread with scissors.
    • And you're free to enjoy your newly button'd shirt! Enjoy!
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 34
过去 30 天: 167
总计 2,661
