跳转到主内容
How to Replace a Broken Window Wand Tilt Mechanism
  1. How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: 步骤 1 中的图像 1,3 How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: 步骤 1 中的图像 2,3 How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: 步骤 1 中的图像 3,3
    • Lift up the wand sleeve with your fingers to clear access for the wand to slide out.
    • Once the sleeve is pushed up, rotate the wand horizontally to unhook it from the tilt mechanism.
  2. How to Replace a Broken Window Wand Tilt Mechanism: 步骤 2 中的图像 1,2 How to Replace a Broken Window Wand Tilt Mechanism: 步骤 2 中的图像 2,2
    • Lift the header board off the window shade by gently prying up and away from the window blind.
  3. How to Replace a Broken Window Wand Tilt Mechanism: 步骤 3 中的图像 1,3 How to Replace a Broken Window Wand Tilt Mechanism: 步骤 3 中的图像 2,3 How to Replace a Broken Window Wand Tilt Mechanism: 步骤 3 中的图像 3,3
    • Unhook the end clips on the window blind by pulling with your fingers toward yourself in an upward motion.
  4. How to Replace a Broken Window Wand Tilt Mechanism: 步骤 4 中的图像 1,2 How to Replace a Broken Window Wand Tilt Mechanism: 步骤 4 中的图像 2,2
    • Remove the window blind by pulling it away from the brackets.
  5. How to Replace a Broken Window Wand Tilt Mechanism: 步骤 5 中的图像 1,3 How to Replace a Broken Window Wand Tilt Mechanism: 步骤 5 中的图像 2,3 How to Replace a Broken Window Wand Tilt Mechanism: 步骤 5 中的图像 3,3
    • Slide the end cap off the header to allow for more access.
    • Lift the center rod in an upward motion to unlock it from the header.
  6. How to Replace a Broken Window Wand Tilt Mechanism: 步骤 6 中的图像 1,3 How to Replace a Broken Window Wand Tilt Mechanism: 步骤 6 中的图像 2,3 How to Replace a Broken Window Wand Tilt Mechanism: 步骤 6 中的图像 3,3
    • Remove the tilt wand mechanism by sliding it off the center rod.
  7. How to Replace a Broken Window Wand Tilt Mechanism: 步骤 7 中的图像 1,3 How to Replace a Broken Window Wand Tilt Mechanism: 步骤 7 中的图像 2,3 How to Replace a Broken Window Wand Tilt Mechanism: 步骤 7 中的图像 3,3
    • Install the new tilt wand mechanism by sliding it on the center rod.
    • Once slid into position, reinsert the center rod by pushing down on the assembly.
  8. How to Replace a Broken Window Wand Tilt Mechanism: 步骤 8 中的图像 1,1
    • Visually inspect alignment, fitment, and proper function of the newly installed tilt wand mechanism.
    • Insure the clip is securely held in place.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 96
过去 30 天: 480
总计 17,683
