跳转到主内容
How to Replace a Broken Blind Slat
你所需要的
  1. How to Replace a Broken Blind Slat, Horizontal Blind Slat: 步骤 1 中的图像 1,1
    • Using the 7/32" flathead screwdriver, gently lift up the buttons located on the bottom rail of the blinds.
    • Make sure to be careful when lifting the bottom buttons to avoid injury and button damage.
  2. How to Replace a Broken Blind Slat: 步骤 2 中的图像 1,2 How to Replace a Broken Blind Slat: 步骤 2 中的图像 2,2
    • Remove the bottom rail buttons to expose knots at the end of the lifting cords.
    • Untie the knots.
  3. How to Replace a Broken Blind Slat: 步骤 3 中的图像 1,1
    • Start at the highest damaged slat.
    • Begin pulling the lifting cords up through the route holes of all the following blind slats.
    • If you don't start from the highest slat, it will result in you doing way more work than you have to.
  4. How to Replace a Broken Blind Slat: 步骤 4 中的图像 1,2 How to Replace a Broken Blind Slat: 步骤 4 中的图像 2,2
    • Again, start with the highest slat.
    • Begin removing the broken slat(s) from in between the ladder strings.
  5. How to Replace a Broken Blind Slat: 步骤 5 中的图像 1,1
    • Slide in the replacement slat(s).
    • Be sure the slat(s) sits in place upon the rungs of the ladder strings.
  6. How to Replace a Broken Blind Slat: 步骤 6 中的图像 1,1
    • With the new replacement slats in place, begin at the highest slat.
    • Create a loop with the lifting cords.
    • Slide the loop through each routing hole on the same side of all the slats.
    • Repeat this step on the other side, and in the middle if your blinds have three routing holes.
  7. How to Replace a Broken Blind Slat: 步骤 7 中的图像 1,3 How to Replace a Broken Blind Slat: 步骤 7 中的图像 2,3 How to Replace a Broken Blind Slat: 步骤 7 中的图像 3,3
    • Once you reach the bottom slat, thread the lifting cords back through the bottom rail.
    • Make sure the lifting cords are even in length and the bottom rail is aligned straight horizontally.
  8. How to Replace a Broken Blind Slat: 步骤 8 中的图像 1,3 How to Replace a Broken Blind Slat: 步骤 8 中的图像 2,3 How to Replace a Broken Blind Slat: 步骤 8 中的图像 3,3
    • Use the 7/32" flathead screwdriver to push the excess lifting cords into the bottom rail holes.
    • Slide the buttons back over the ends of the cords.
    • At each bottom rail button, double knot the lifting cords.
  9. How to Replace a Broken Blind Slat: 步骤 9 中的图像 1,1
    • Plug the buttons back into the bottom rail.
  10. How to Replace a Broken Blind Slat: 步骤 10 中的图像 1,2 How to Replace a Broken Blind Slat: 步骤 10 中的图像 2,2
    • Lastly, gently hammer the bottom rail buttons with the handle of the 7/32" flathead screwdriver to ensure the button is securely fastened.
结论
3等其他人完成本指南。
2条评论
Very good tutorial. Thank you.
LaReisa Cares - 回复
What happened when that string retracts and goes missing ?
Mary Nguyen - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 70
过去 30 天: 402
总计 15,897
