跳转到主内容
How to Replace a Bicycle Bell Disc
你所需要的
  1. How to Replace a Bicycle Bell Disc, Disc Bell: 步骤 1 中的图像 1,2 How to Replace a Bicycle Bell Disc, Disc Bell: 步骤 1 中的图像 2,2
    • Unscrew the exterior bell housing by rotating clockwise, then remove the housing.
  2. How to Replace a Bicycle Bell Disc: 步骤 2 中的图像 1,2 How to Replace a Bicycle Bell Disc: 步骤 2 中的图像 2,2
    • Rotate the parallel bars clockwise until they separate from the rod they're mounted on.
  3. How to Replace a Bicycle Bell Disc: 步骤 3 中的图像 1,2 How to Replace a Bicycle Bell Disc: 步骤 3 中的图像 2,2
    • Remove the rubber discs.
    • Grab your new rubber discs and insert one at each end of the parallel bars.
    • Make sure center of the rubber discs are held in place by the pins.
  4. How to Replace a Bicycle Bell Disc: 步骤 4 中的图像 1,1
    • Test and rotate the discs with your finger to see if it is the appropriate size.
    • If the disc does not rotate easily, change the size of your metal disc to a narrower one.
  5. How to Replace a Bicycle Bell Disc: 步骤 5 中的图像 1,2 How to Replace a Bicycle Bell Disc: 步骤 5 中的图像 2,2
    • Rotate the parallel bars counterclockwise, into their original position.
  6. How to Replace a Bicycle Bell Disc: 步骤 6 中的图像 1,2 How to Replace a Bicycle Bell Disc: 步骤 6 中的图像 2,2
    • Replace the exterior housing and rotate it counterclockwise until it's fully secure.
结论
Your bell should now be ringing like new!
Susan
于01/19/22注册
133 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 58
总计 2,096
