跳转到主内容
How to Replace a Beaded Bracelet String
你所需要的
  1. How to Replace a Beaded Bracelet String, String: 步骤 1 中的图像 1,2 How to Replace a Beaded Bracelet String, String: 步骤 1 中的图像 2,2
    • Test your bracelet by wearing it on your wrist.
    • If it is loose, sagging (as pictured), or fully snapped, this is a sign that you may need to replace the string.
  2. How to Replace a Beaded Bracelet String: 步骤 2 中的图像 1,1
    • Cut the old string using scissors.
  3. How to Replace a Beaded Bracelet String: 步骤 3 中的图像 1,1
    • Separate the beads from the old string.
  4. How to Replace a Beaded Bracelet String: 步骤 4 中的图像 1,1
    • Measure the new string by wrapping it 1.5 times around your wrist.
    • If you want a loose fit, add extra slack, otherwise pull it flush against skin.
    • Make sure to leave at least 2 in (5.1cm) of excess string for the knot.
  5. How to Replace a Beaded Bracelet String: 步骤 5 中的图像 1,1
    • Cut the new string at the desired length using scissors.
  6. How to Replace a Beaded Bracelet String: 步骤 6 中的图像 1,1
    • Thread the beads onto the new string one at a time.
    • You can use tweezers to hold the beads as you thread.
  7. How to Replace a Beaded Bracelet String: 步骤 7 中的图像 1,2 How to Replace a Beaded Bracelet String: 步骤 7 中的图像 2,2
    • Tie a square knot to secure the bracelet.
    • Cross both ends to form an "X" shape.
    • Loop one end of the string over the other to form a simple knot.
    • Tie another simple knot, but this time, loop in the opposite direction. If you initially looped the right side over the left, loop the left side over the right, and vice versa.
    • Pull tight to form a square knot.
  8. How to Replace a Beaded Bracelet String: 步骤 8 中的图像 1,1
    • As an optional step, apply a dot of super glue to the knot.
    • Wait until the super glue fully dries before moving on, otherwise the knot may come undone.
  9. How to Replace a Beaded Bracelet String: 步骤 9 中的图像 1,1
    • Trim the excess string.
    • Make sure to leave at least 1/2 in (1.3cm) of excess string for the knot.
  10. How to Replace a Beaded Bracelet String: 步骤 10 中的图像 1,2 How to Replace a Beaded Bracelet String: 步骤 10 中的图像 2,2
    • Test your bracelet by wearing it again. It should have a tighter fit.
结论
Lucas Wang
于01/30/24注册
181 声望
撰写一个指南
团队
UC Davis, Team 2-5, Andersen Winter 2024 UC Davis, Team 2-5, Andersen Winter 2024 的会员
UCD-ANDERSEN-W24S2G5
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 31
总计 187
