跳转到主内容
How to Replace a Backpack Buckle (with sewing)
你所需要的
  1. How to Replace a Backpack Buckle (with sewing), Locate the repair area: 步骤 1 中的图像 1,2 How to Replace a Backpack Buckle (with sewing), Locate the repair area: 步骤 1 中的图像 2,2
    • Identify where the broken buckle is and prepare the tools needed for the repair.
  2. How to Replace a Backpack Buckle (with sewing), Clean the area: 步骤 2 中的图像 1,3 How to Replace a Backpack Buckle (with sewing), Clean the area: 步骤 2 中的图像 2,3 How to Replace a Backpack Buckle (with sewing), Clean the area: 步骤 2 中的图像 3,3
    • Use a seam ripper to unstitch the strap.
    • Remove the broken buckle and check that it is compatible with the replacement part.
    • Tip: The new buckle size must match the strap width.
  3. How to Replace a Backpack Buckle (with sewing), Test the replacement part: 步骤 3 中的图像 1,3 How to Replace a Backpack Buckle (with sewing), Test the replacement part: 步骤 3 中的图像 2,3 How to Replace a Backpack Buckle (with sewing), Test the replacement part: 步骤 3 中的图像 3,3
    • Set the top part of the buckle aside (green circle).
    • Take the bottom part of the buckle (blue circle) and put it into the strap.
    • Hold it together with both hands and then insert it into the seam of the backpack.
  4. How to Replace a Backpack Buckle (with sewing), Stitch the bottom buckle in place: 步骤 4 中的图像 1,2 How to Replace a Backpack Buckle (with sewing), Stitch the bottom buckle in place: 步骤 4 中的图像 2,2
    • Following the last step, keep holding together the strap with the bottom buckle with both hands and gently place it on the sewing machine.
    • Once the strap is set in place, start stitching the area.
    • Use a pair of scissors to cut any loose threads.
  5. How to Replace a Backpack Buckle (with sewing), Stitch the top buckle piece: 步骤 5 中的图像 1,3 How to Replace a Backpack Buckle (with sewing), Stitch the top buckle piece: 步骤 5 中的图像 2,3 How to Replace a Backpack Buckle (with sewing), Stitch the top buckle piece: 步骤 5 中的图像 3,3
    • Repeat the previous steps to stitch the top buckle piece.
  6. How to Replace a Backpack Buckle (with sewing), Finished and ready!: 步骤 6 中的图像 1,3 How to Replace a Backpack Buckle (with sewing), Finished and ready!: 步骤 6 中的图像 2,3 How to Replace a Backpack Buckle (with sewing), Finished and ready!: 步骤 6 中的图像 3,3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
结论
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
于07/19/23注册
10,230 声望
创作了66篇指南
团队
INTERSPORT INTERSPORT 的会员
Community
25 名成员
创作了169篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 39
总计 454
