跳转到主内容
加入维修社区 - 创建账户
How to Replace a 2017 Honda Civic LX Cabin Filter
浏览量: 1.1万
浏览统计数据:
过去24小时
6
过去 7 天:
56
过去 30 天:
210
总计
10,697
评论: 0
暂时还没有人对本指南发表评论。你想做第一个评论的人吗?
Go to guide comments
已完成: 3
3 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 1
1 人收藏(并订阅)了本指南。你会是下一个吗?
所需时间: 10 - 15 分钟
难度: 简单
In this set of instructions, you’ll find easy steps on how to properly remove and replace an air filter in a 2017 Honda Civic LX. A cabin air filter’s job is to remove dust, pollutants, pollen, and other small particles from your car’s air flow. Therefore, it fills with these particles and needs to be replaced between every 15,000 and 30,000 miles in order to properly do its job. If your air flow is weak, smells musty, or makes a whistling noise, those are all signs you’re due for a new cabin filter.
All you’ll need is a new AQ1182 Cabin Air Filter and a few minutes to remove the proper parts, remove the old filter, and replace it with the brand new one. Be careful when removing the old filter that you don’t accidentally inhale any of the particles. Linked below is a video of replacing an air filter on a similar (but not exact) Honda Civic model, if you need the extra visual aid.
https://www.youtube.com/watch?v=iZgI2nKz...
你所需要的
工具
    1. How to Replace a 2017 Honda Civic LX Cabin Filter, Cabin Filter: 步骤 1 中的图像 1,1
      • Direct your attention to the glove compartment directly in front of the front passenger seat.
      询问修复机器人
      添加评论
    2. How to Replace a 2017 Honda Civic LX Cabin Filter: 步骤 2 中的图像 1,2 How to Replace a 2017 Honda Civic LX Cabin Filter: 步骤 2 中的图像 2,2
      • Open the glove compartment using the handle on the left-hand side.
      • It will open slightly towards you.
      • If you have any items in the glove compartment, remove them and set them aside.
      询问修复机器人
      添加评论
    3. How to Replace a 2017 Honda Civic LX Cabin Filter: 步骤 3 中的图像 1,2 How to Replace a 2017 Honda Civic LX Cabin Filter: 步骤 3 中的图像 2,2
      • Reach inside the glove compartment and press on the two outer walls on each side of the storage box.
      • Lower the glove compartment down to the ground.
      询问修复机器人
      添加评论
    4. How to Replace a 2017 Honda Civic LX Cabin Filter: 步骤 4 中的图像 1,3 How to Replace a 2017 Honda Civic LX Cabin Filter: 步骤 4 中的图像 2,3 How to Replace a 2017 Honda Civic LX Cabin Filter: 步骤 4 中的图像 3,3
      • Reach into the space behind where the storage box previously rested and pull out the black, plastic panel with raised hexagonal lines.
      • This is the cover for the cabin air filter.
      询问修复机器人
      添加评论
    5. How to Replace a 2017 Honda Civic LX Cabin Filter: 步骤 5 中的图像 1,3 How to Replace a 2017 Honda Civic LX Cabin Filter: 步骤 5 中的图像 2,3 How to Replace a 2017 Honda Civic LX Cabin Filter: 步骤 5 中的图像 3,3
      • Pull out the cloth air filter from the space behind the air filter cover.
      • Dispose of the old air filter.
      询问修复机器人
      添加评论
    6. How to Replace a 2017 Honda Civic LX Cabin Filter: 步骤 6 中的图像 1,2 How to Replace a 2017 Honda Civic LX Cabin Filter: 步骤 6 中的图像 2,2
      • Unwrap your new air filter and insert it into the empty air filter compartment.
      • On the side of your new air filter you will see air flow markings. Be sure to insert the new air filter so that the air flow markings point down to the ground.
      询问修复机器人
      添加评论
    7. How to Replace a 2017 Honda Civic LX Cabin Filter: 步骤 7 中的图像 1,3 How to Replace a 2017 Honda Civic LX Cabin Filter: 步骤 7 中的图像 2,3 How to Replace a 2017 Honda Civic LX Cabin Filter: 步骤 7 中的图像 3,3
      • Double-check that the air filter is securely all the way into the compartment.
      • Place the black, plastic air filter cover back into place and push it firmly to secure.
      询问修复机器人
      添加评论
    8. How to Replace a 2017 Honda Civic LX Cabin Filter: 步骤 8 中的图像 1,1
      • Push on the sides of the storage box and lift the glove compartment back into place.
      询问修复机器人
      添加评论
    9. How to Replace a 2017 Honda Civic LX Cabin Filter: 步骤 9 中的图像 1,1
      • Close your glove compartment and you're done!
      询问修复机器人
      添加评论
结论
Enjoy a breath of fresh air as your cabin air filter has now been replaced!
取消:我没有完成这个指南。
3等其他人完成本指南。
作者
与
Grace Hanson
于10/04/20注册
249 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 56
过去 30 天: 210
总计 10,697
