跳转到主内容
How to Replace Velcro on a Baseball Cap
你所需要的
  1. How to Replace Velcro on a Baseball Cap, How to Replace Velcro on a Baseball Cap: 步骤 1 中的图像 1,3 How to Replace Velcro on a Baseball Cap, How to Replace Velcro on a Baseball Cap: 步骤 1 中的图像 2,3 How to Replace Velcro on a Baseball Cap, How to Replace Velcro on a Baseball Cap: 步骤 1 中的图像 3,3
    • Use a seam ripper to remove the stitching between the velcro and the hat.
    • Make sure to fully remove the velcro by also seam ripping the fold inside the hat.
    • Repeat this step on the other strap.
  2. How to Replace Velcro on a Baseball Cap: 步骤 2 中的图像 1,2 How to Replace Velcro on a Baseball Cap: 步骤 2 中的图像 2,2
    • Use a measuring tape to measure how much velcro you will need.
  3. How to Replace Velcro on a Baseball Cap: 步骤 3 中的图像 1,1
    • Cut the precise amount of velcro to be sewn onto the hat.
  4. How to Replace Velcro on a Baseball Cap: 步骤 4 中的图像 1,1
    • Pin the new velcro onto the hat.
    • This will make sure both pieces stay in place when you start to sew the velcro in place.
  5. How to Replace Velcro on a Baseball Cap: 步骤 5 中的图像 1,3 How to Replace Velcro on a Baseball Cap: 步骤 5 中的图像 2,3 How to Replace Velcro on a Baseball Cap: 步骤 5 中的图像 3,3
    • To prepare for sewing, thread the needle with a thread color of your choice.
    • Pull the thread through the loop.
    • Measure about 24 inches
    • Make sure to leave an even amount of thread on either side of the needle.
    • 12 inches on each side
    • Cut the thread.
    • Knot the ends of the thread together to secure.
  6. How to Replace Velcro on a Baseball Cap: 步骤 6 中的图像 1,3 How to Replace Velcro on a Baseball Cap: 步骤 6 中的图像 2,3 How to Replace Velcro on a Baseball Cap: 步骤 6 中的图像 3,3
    • Use a running stitch to secure the velcro to the strap of the cap.
    • To do a running stitch: bring the needle up through the cap side of the strap and then the velcro until the knot at the end of the thread hits the fabric.
    • At this point, bring the needle back down through the velcro a few millimeters from where you started, following the direction you're trying to sew.
    • Keep bringing the needle up and down through the strap and velcro, moving the same distance each time. Repeat this until you have sewn around the entire piece of velcro to secure it.
  7. How to Replace Velcro on a Baseball Cap: 步骤 7 中的图像 1,1
    • When you come to the end, knot the thread next to the last running stitch to finish it.
  8. How to Replace Velcro on a Baseball Cap: 步骤 8 中的图像 1,1
    • Repeat steps 4 - 7 on the remaining strap using the other side of the velcro.
    • Once finished, the velcro should be securely sewn on the baseball cap and ready to use.
终点
2等其他人完成本指南。
Vi Truong
于10/26/18注册
221 声望
撰写一个指南
团队
UC Davis, Team S1-G9, Bender Fall 2018 UC Davis, Team S1-G9, Bender Fall 2018 的会员
UCD-BENDER-F18S1G9
3 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 32
过去 30 天: 210
总计 21,985
