跳转到主内容
How to Replace T-fal Avante T24-B Toaster Lever
你所需要的
  1. How to Replace T-fal Avante T24-B Toaster Lever, T-fal Avante T24-B Toaster Lever: 步骤 1 中的图像 1,1
    • Make sure the toaster is unplugged before beginning.
  2. How to Replace T-fal Avante T24-B Toaster Lever: 步骤 2 中的图像 1,3 How to Replace T-fal Avante T24-B Toaster Lever: 步骤 2 中的图像 2,3 How to Replace T-fal Avante T24-B Toaster Lever: 步骤 2 中的图像 3,3
    • Remove the snap-on buttons from the front of the toaster.
    • They can be removed by pulling with your hands or gently prying with a flat tool.
  3. How to Replace T-fal Avante T24-B Toaster Lever: 步骤 3 中的图像 1,3 How to Replace T-fal Avante T24-B Toaster Lever: 步骤 3 中的图像 2,3 How to Replace T-fal Avante T24-B Toaster Lever: 步骤 3 中的图像 3,3
    • Flip the toaster so that you can see its underside.
    • Remove the seven 20 mm Torx T3 screws from the bottom of the toaster.
  4. How to Replace T-fal Avante T24-B Toaster Lever: 步骤 4 中的图像 1,2 How to Replace T-fal Avante T24-B Toaster Lever: 步骤 4 中的图像 2,2
    • Turn the toaster so that you can access the back of the toaster
    • Remove the 3 15 mm Torx T3 screws from the back of the toaster.
  5. How to Replace T-fal Avante T24-B Toaster Lever: 步骤 5 中的图像 1,2 How to Replace T-fal Avante T24-B Toaster Lever: 步骤 5 中的图像 2,2
    • Pull off the toaster casing.
  6. How to Replace T-fal Avante T24-B Toaster Lever: 步骤 6 中的图像 1,2 How to Replace T-fal Avante T24-B Toaster Lever: 步骤 6 中的图像 2,2
    • Unplug the casing so that it does not get in your way.
    • Unplug both wires connecting the casing to the internals of the toaster.
  7. How to Replace T-fal Avante T24-B Toaster Lever: 步骤 7 中的图像 1,3 How to Replace T-fal Avante T24-B Toaster Lever: 步骤 7 中的图像 2,3 How to Replace T-fal Avante T24-B Toaster Lever: 步骤 7 中的图像 3,3
    • Pry both sides of the broken lever at the front of the toaster away and remove it.
  8. How to Replace T-fal Avante T24-B Toaster Lever: 步骤 8 中的图像 1,3 How to Replace T-fal Avante T24-B Toaster Lever: 步骤 8 中的图像 2,3 How to Replace T-fal Avante T24-B Toaster Lever: 步骤 8 中的图像 3,3
    • Snap the replacement lever into place.
    • Attach one side first, then snap the other side on to fully attach the lever.
结论
Cameron Johnson
于01/16/23注册
157 声望
撰写一个指南
团队
2指南评论
Thank you so much!
S J - 回复
where do you get the replacement lever ?
Francois Rehel - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 33
总计 1,197
