跳转到主内容
How to Replace Scott Mountain Bike Handlebars
你所需要的
  1. How to Replace Scott Mountain Bike Handlebars, Scott Mountain Bike Handlebars: 步骤 1 中的图像 1,2 How to Replace Scott Mountain Bike Handlebars, Scott Mountain Bike Handlebars: 步骤 1 中的图像 2,2
    • Prop bike upright
    • Unscrew the hex bolts holding the front and rear shifter in place.
    • Use the H4 size hex wrench
    • Repeat for other side of handlebars.
  2. How to Replace Scott Mountain Bike Handlebars: 步骤 2 中的图像 1,1
    • Slide the shifters toward the center of the handlebars so there is a gap between them and the grips.
  3. How to Replace Scott Mountain Bike Handlebars: 步骤 3 中的图像 1,1
    • Use a flathead screwdriver to wedge a gap between the grip and the handlebars.
    • Twist grip around until it comes off of handlebar.
  4. How to Replace Scott Mountain Bike Handlebars: 步骤 4 中的图像 1,1
    • Slide the shifters off of the end of the handlebars.
    • Let them hang on the bike.
  5. How to Replace Scott Mountain Bike Handlebars: 步骤 5 中的图像 1,1
    • Unscrew the hex bolts holding the center bracket in place.
    • Use H3 hex wrench.
    • Place center bracket and hex screws off to the side. They will be needed in the next step.
  6. How to Replace Scott Mountain Bike Handlebars: 步骤 6 中的图像 1,1
    • Attach new handlebars and screw the center bracket back in place.
    • Make sure that handlebars are centered.
  7. How to Replace Scott Mountain Bike Handlebars: 步骤 7 中的图像 1,1
    • Slide the shifters back onto the handlebars so that the numbers are upright.
    • Do not screw them back in place yet.
  8. How to Replace Scott Mountain Bike Handlebars: 步骤 8 中的图像 1,1
    • Slide the handlebar grips back onto the ends of the handlebars.
    • Slide the shifters back against the grips and screw them into place.
结论
By following these steps, you will have your bike ready in no time.
Sean Slater
于02/24/15注册
139 声望
撰写一个指南
团队
Cal Poly, Team 23-3, Green Winter 2015 Cal Poly, Team 23-3, Green Winter 2015 的会员
CPSU-GREEN-W15S23G3
6 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 1,717
