跳转到主内容
How to Replace PopSockets Grip Adhesive
你所需要的
  1. How to Replace PopSockets Grip Adhesive, Adhesive: 步骤 1 中的图像 1,3 How to Replace PopSockets Grip Adhesive, Adhesive: 步骤 1 中的图像 2,3 How to Replace PopSockets Grip Adhesive, Adhesive: 步骤 1 中的图像 3,3
    • Gently tear off the worn out adhesive from the grip, using your fingers or a pair of tweezers.
    • Make sure the entire worn out adhesive is torn off.
  2. How to Replace PopSockets Grip Adhesive: 步骤 2 中的图像 1,2 How to Replace PopSockets Grip Adhesive: 步骤 2 中的图像 2,2
    • Rub off any remaining adhesive residue with alcohol pads.
    • Feel free to put the grip in hot water (not boiling) to help loosen any stubborn residue.
  3. How to Replace PopSockets Grip Adhesive: 步骤 3 中的图像 1,2 How to Replace PopSockets Grip Adhesive: 步骤 3 中的图像 2,2
    • Wipe off any moisture from the previous step using a paper towel or a dry table napkin.
    • Make sure it is completely dry before moving on because it will make it easier for you to attach the new adhesive.
  4. How to Replace PopSockets Grip Adhesive: 步骤 4 中的图像 1,3 How to Replace PopSockets Grip Adhesive: 步骤 4 中的图像 2,3 How to Replace PopSockets Grip Adhesive: 步骤 4 中的图像 3,3
    • Peel off the protective backing from the new adhesive.
  5. How to Replace PopSockets Grip Adhesive: 步骤 5 中的图像 1,2 How to Replace PopSockets Grip Adhesive: 步骤 5 中的图像 2,2
    • Gently place the new adhesive onto the clean area of the grip.
    • Make sure that the adhesive is properly aligned with the clean area of the grip.
  6. How to Replace PopSockets Grip Adhesive: 步骤 6 中的图像 1,1
    • Flatten the attached adhesive with your thumbs to get rid off any air bubbles.
  7. How to Replace PopSockets Grip Adhesive: 步骤 7 中的图像 1,3 How to Replace PopSockets Grip Adhesive: 步骤 7 中的图像 2,3 How to Replace PopSockets Grip Adhesive: 步骤 7 中的图像 3,3
    • Weight the pop socket down using a book or any heavy item with a flat surface.
    • Leave it for at least 5 minutes to ensure firm attachment.
结论
After completing the steps, you can peel off the "red" protective backing strip of the new adhesive and firmly attach it to any device as you please.
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 42
总计 299
