需要更好的图片
更好的照片将改善本指南。请帮助拍摄,编辑,或上传新的图片!
需要更多图片
更多的图片将使本指南的操作过程一清二楚。
简介
转到步骤 1 ↓When exposed to the elements wooden decks can warp and rot to the point that the boards become hazards. In order to remove these hazards, the rotted boards must be replaced.
Before using this guide, check to see if any deck boards need replacing. Look to see if the boards are splintered, cracked, or warped (the wood is no longer even). If any of the deck boards look like that, those are the onces that will need replacing.
By following this guide you’ll end up bringing back the structural integrity of your deck as well as improve the appearance of your deck too!
你所需要的
工具
Mark which boards need replacing.
Once the boards that are to be removed are marked, measure the boards.
Write down the measurements for later.
For example, if your board is 9ft you will need a 10ft board.
Use the Dremel tool in order to clear the old paint from the drive of the screw on the boards previously marked.
The drive of the screw is where the screwdriver will fit.
Use the electric screwdriver in order to remove the old nails.
Once all the nails are out you can lift the board out and sweep any rotted wood or debris from where the boards were.
