跳转到主内容
How to Replace Hot and Cold Water Pipes for a Washer
你所需要的
  1. How to Replace Hot and Cold Water Pipes for a Washer, How to Replace Hot and Cold Water Pipes for a Washer: 步骤 1 中的图像 1,1
    • Before starting this guide, shut off your water to the washer and dryer. In this guide, valves are used. Some newer setups may use levers.
    • Mark the hot and cold water pipelines with a marker for proper visuals.
    • Hot water
    • Cold water
  2. How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: 步骤 2 中的图像 1,3 How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: 步骤 2 中的图像 2,3 How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: 步骤 2 中的图像 3,3
    • Using an adjustable wrench, disconnect the pipes carefully from the water supply side and the washer side.
    • After the pipes are disconnected, re-check the leakage and rust in the washer installation.
  3. How to Replace Hot and Cold Water Pipes for a Washer: 步骤 3 中的图像 1,1
    • Rotate the adjustable wrench in a counter-clockwise direction to loosen the pipe connection.
    • Make sure to remove the old white Teflon tape. Use a bucket and a piece of cloth for water damps from the connection.
  4. How to Replace Hot and Cold Water Pipes for a Washer, Prepare the new pipes: 步骤 4 中的图像 1,1
    • Set up the new pipes to be installed.
    • Check for blockage or any cracks in the valve.
  5. How to Replace Hot and Cold Water Pipes for a Washer, Wrap new Teflon tape: 步骤 5 中的图像 1,1
    • Wrap the new piece of Teflon tape around the shut-off valve connection.
  6. How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: 步骤 6 中的图像 1,3 How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: 步骤 6 中的图像 2,3 How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: 步骤 6 中的图像 3,3
    • Install and connect the new pipes using an adjustable wrench.
  7. How to Replace Hot and Cold Water Pipes for a Washer, Return the water supply: 步骤 7 中的图像 1,2 How to Replace Hot and Cold Water Pipes for a Washer, Return the water supply: 步骤 7 中的图像 2,2
    • Rotate the pipes in a clockwise direction to tighten up.
    • Turn on the water supply. Perform a quick wash and check the connection.
结论
  • This guide contains easy steps of instructions to be followed if your pipes of the washer are needed to be changed.
另外一个人完成了本指南。
Jenish
于01/22/21注册
169 声望
撰写一个指南
团队
一条评论
Those are hoses. Pipes are in the wall
NitWit - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 46
过去 30 天: 188
总计 7,803
