跳转到主内容
加入维修社区 - 创建账户
How to Replace HID Headlight Bulbs
    1. How to Replace HID Headlight Bulbs, HID Headlight Bulb: 步骤 1 中的图像 1,2 How to Replace HID Headlight Bulbs, HID Headlight Bulb: 步骤 1 中的图像 2,2
      • Open the hood and then locate the back of the headlights.
      询问修复机器人
      添加评论
    2. How to Replace HID Headlight Bulbs: 步骤 2 中的图像 1,1
      • Remove the cap covers behind the headlights.
      询问修复机器人
      添加评论
    3. How to Replace HID Headlight Bulbs: 步骤 3 中的图像 1,2 How to Replace HID Headlight Bulbs: 步骤 3 中的图像 2,2
      • Once you can see the OEM headlight bulb, twist and unlock to take it out.
      询问修复机器人
      添加评论
    4. How to Replace HID Headlight Bulbs: 步骤 4 中的图像 1,2 How to Replace HID Headlight Bulbs: 步骤 4 中的图像 2,2
      • For a lot of D1S and D3S, there's a bulb retainer, which you will need to remove.
      询问修复机器人
      添加评论
    5. How to Replace HID Headlight Bulbs: 步骤 5 中的图像 1,1
      • Examine your stock bulb. Make sure that the labeling on the OEM bulb is the same as the new HID bulb.
      • For example, this particular vehicle uses D1S stock bulb. You'll need to make sure that the HID replacement bulb is also labeled as D1S.
      • D1S and D3S are not interchangeable, so if you find that the labeling does not match, you will need to exchange for the correct size.
      询问修复机器人
      添加评论
    6. How to Replace HID Headlight Bulbs: 步骤 6 中的图像 1,3 How to Replace HID Headlight Bulbs: 步骤 6 中的图像 2,3 How to Replace HID Headlight Bulbs: 步骤 6 中的图像 3,3
      • Take a look at the pins inside of the bulb. You can see that there is 1 pin by itself, a gap, and then 2 pins together. When you connect the new HID headlight bulb to the adapter, the pin direction needs to match! Look closely at the adapter and you will see numbers denoting slots 1,2, and 4.
      • Make sure that the pins on the HID headlight bulb and the pin slots on the adapter directly match prior to connection. If you connect the HID headlight bulb and the adapter the wrong way, the connection will still go in, but the incorrect insert WILL cause the bulb to have issues such as not lighting up, flickering, or damage to your vehicle.
      • So before connecting the HID headlight bulb to the adapter, make sure that the pins from the HID headlight bulb match the corresponding open slots on the adapter.
      询问修复机器人
      添加评论
    7. How to Replace HID Headlight Bulbs: 步骤 7 中的图像 1,2 How to Replace HID Headlight Bulbs: 步骤 7 中的图像 2,2
      • Now you can install the HID headlight bulb back with the original retainer and then insert it back the same way you removed the OEM bulb.
      添加评论
    8. How to Replace HID Headlight Bulbs: 步骤 8 中的图像 1,2 How to Replace HID Headlight Bulbs: 步骤 8 中的图像 2,2
      • Put all the components back in place and enjoy your new HID headlights.
      询问修复机器人
      添加评论
结论
As you can see, it's very straight forward to install. Installing this HID Replacement Bulb will give you light when yours burnt out.
取消:我没有完成这个指南。
7等其他人完成本指南。
Eric Wu
于01/21/15注册
3,600 声望
创作了23篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 75
过去 30 天: 346
总计 10,485
