跳转到主内容
How to Replace Damaged Clarinet Cork With Foam
你所需要的
  1. How to Replace Damaged Clarinet Cork With Foam, How to Replace Damaged Clarinet Cork With Foam: 步骤 1 中的图像 1,1
    • Take your clarinet and identify where the cork is damaged and assess the extent of the damaged cork.
  2. How to Replace Damaged Clarinet Cork With Foam: 步骤 2 中的图像 1,1
    • With a small razor, start cutting the cork by creating a line vertically and horizontally.
  3. How to Replace Damaged Clarinet Cork With Foam: 步骤 3 中的图像 1,2 How to Replace Damaged Clarinet Cork With Foam: 步骤 3 中的图像 2,2
    • After cutting the cork vertically and horizontally, try removing as much cork as possible.
  4. How to Replace Damaged Clarinet Cork With Foam: 步骤 4 中的图像 1,2 How to Replace Damaged Clarinet Cork With Foam: 步骤 4 中的图像 2,2
    • With the small razor used to cut the cork, cut a piece of foam.
    • The size will depend on what part of the clarinet you are fixing.
    • Use a glue gun to bond the foam to the clarinet tenon.
  5. How to Replace Damaged Clarinet Cork With Foam: 步骤 5 中的图像 1,1
    • After gluing the piece of foam, let it dry.
    • Assemble the clarinet until it fits completely.
  6. How to Replace Damaged Clarinet Cork With Foam: 步骤 6 中的图像 1,1
    • Finally, the clarinet is fixed, and it will function properly until you are able to replace the cork.
结论
After complete all the steps the clarinet is ready and the musician may continue performing with it. A simple repair like this allows the musician to order clarinet parts that’ll take awhile to arrive.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 313
