简介
Cracked tile can be unsightly and can lead to larger foundation issues in the long run, but replacing a broken tile can be a simple and straightforward fix. After finding matching tile and grout, the replacement will be all but unnoticeable.
你所需要的
Use a painter's tool or putty knife to remove the grout from around the cracked tile.
Using an edge or corner of your painter's tool or putty knife, scrape the grout along the perimeter of the broken tile.
After the adhesive has dried, add water to a small amount of grout until it's the consistency of toothpaste.
Fill in the area around the new tile, making sure the new grout matches the height of the surrounding grout.
Use a moist sponge to wipe diagonally across the tile, cleaning off excess grout after each wipe.
Allow the grout to dry and then resume normal use.
10等其他人完成本指南。
