跳转到主内容
How to Replace Concealed Cabinet Hinges
你所需要的
  1. How to Replace Concealed Cabinet Hinges, Hinge: 步骤 1 中的图像 1,3 How to Replace Concealed Cabinet Hinges, Hinge: 步骤 1 中的图像 2,3 How to Replace Concealed Cabinet Hinges, Hinge: 步骤 1 中的图像 3,3
    • Remove the screws that are attached to the cabinet door.
    • Unscrew the top and bottom hinges even if you are only replacing one hinge.
    • Remove the cabinet door from the hinge.
    • You may need to wiggle or pry the door off.
  2. How to Replace Concealed Cabinet Hinges: 步骤 2 中的图像 1,2 How to Replace Concealed Cabinet Hinges: 步骤 2 中的图像 2,2
    • Remove the screws that go into the cabinet frame from the hinge, then remove the hinge.
    • Only the hinge being replaced needs to be removed.
  3. How to Replace Concealed Cabinet Hinges: 步骤 3 中的图像 1,3 How to Replace Concealed Cabinet Hinges: 步骤 3 中的图像 2,3 How to Replace Concealed Cabinet Hinges: 步骤 3 中的图像 3,3
    • Insert the new hinge into the cabinet door's pre-cut hole.
    • Attach the hinge with the provided screws.
    • To avoid striping the screws, do not over tighten.
  4. How to Replace Concealed Cabinet Hinges: 步骤 4 中的图像 1,1
    • Reattach the cabinet door to the cabinet frame.
    • Do not tighten the screws all the way. You will need to align the door later.
    • You may need a friend to hold the door while you screw it back into place.
  5. How to Replace Concealed Cabinet Hinges: 步骤 5 中的图像 1,2 How to Replace Concealed Cabinet Hinges: 步骤 5 中的图像 2,2
    • Lift or lower the cabinet door to align the hinges with its original location.
    • Changes in wood stain can serve as a useful alignment guide.
    • Tighten all the screws.
  6. How to Replace Concealed Cabinet Hinges: 步骤 6 中的图像 1,3 How to Replace Concealed Cabinet Hinges: 步骤 6 中的图像 2,3 How to Replace Concealed Cabinet Hinges: 步骤 6 中的图像 3,3
    • Use this step to adjust the amount of space between the cabinet door and the cabinet frame.
    • Loosen the adjustment screws, but do not remove them.
    • Slide the cabinet door to your desired position.
    • Tighten the screws.
  7. How to Replace Concealed Cabinet Hinges: 步骤 7 中的图像 1,1
    • Use this step if your cabinet door closes too hard or does not completely close.
    • Tighten this screw to keep the cabinet door from closing too hard. Loosen the screw to allow the cabinet door to close completely.
    • Do not completely remove this screw.
终点
4等其他人完成本指南。
Naomi Frazier
于04/28/17注册
171 声望
撰写一个指南
团队
UC Davis, Team S4-G4, Cole Spring 2017 UC Davis, Team S4-G4, Cole Spring 2017 的会员
UCD-COLE-S17S4G4
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 23
过去 30 天: 102
总计 28,143
