跳转到主内容
How to Replace Broken Glass on a Picture Frame
你所需要的
  1. How to Replace Broken Glass on a Picture Frame, Glass on Picture Frame: 步骤 1 中的图像 1,3 How to Replace Broken Glass on a Picture Frame, Glass on Picture Frame: 步骤 1 中的图像 2,3 How to Replace Broken Glass on a Picture Frame, Glass on Picture Frame: 步骤 1 中的图像 3,3
    • Undo the fasteners holding the back onto the frame.
    • Grab the backing to pull it away from the frame.
    • The back of some picture frames completely detaches from the frame. The frame in this guide does not.
  2. How to Replace Broken Glass on a Picture Frame: 步骤 2 中的图像 1,2 How to Replace Broken Glass on a Picture Frame: 步骤 2 中的图像 2,2
    • Set the hook of your measuring tape against one of the inside edges of the frame.
    • Pull the measuring tape to the inside edge of the opposite side and record the measurement.
    • Repeat this step on the remaining side.
  3. How to Replace Broken Glass on a Picture Frame: 步骤 3 中的图像 1,3 How to Replace Broken Glass on a Picture Frame: 步骤 3 中的图像 2,3 How to Replace Broken Glass on a Picture Frame: 步骤 3 中的图像 3,3
    • Set the hook of your measuring tape on the top right corner of the new glass.
    • Pull the measuring tape to the first measurement you got from the previous step and mark it with a sharpie.
    • Repeat this step on the same corner going in the other direction for the second measurement.
  4. How to Replace Broken Glass on a Picture Frame: 步骤 4 中的图像 1,2 How to Replace Broken Glass on a Picture Frame: 步骤 4 中的图像 2,2
    • Align the cutting mat along the marks you made on the glass.
    • Place the china marker on one edge of the glass, and use the cutting mat to help create a line going to the other end.
    • Place the blade of the glass cutter on the edge of the glass, and follow the same path you created with the china marker to score the glass.
    • Attempt to keep the glass cutter straight and firmly press down while scoring the glass.
  5. How to Replace Broken Glass on a Picture Frame: 步骤 5 中的图像 1,3 How to Replace Broken Glass on a Picture Frame: 步骤 5 中的图像 2,3 How to Replace Broken Glass on a Picture Frame: 步骤 5 中的图像 3,3
    • Align the scored mark you created on the glass to an edge of a table.
    • Place one hand in the middle of the glass on the table, and grab the end hanging off the table with your other hand.
    • Press down gently on the glass with both hands to separate both pieces.
    • When the glass separates, take care not to drop it. Dropping the glass could result in injury.
  6. How to Replace Broken Glass on a Picture Frame: 步骤 6 中的图像 1,3 How to Replace Broken Glass on a Picture Frame: 步骤 6 中的图像 2,3 How to Replace Broken Glass on a Picture Frame: 步骤 6 中的图像 3,3
    • Repeat the same process for the other side of the uncut glass.
  7. How to Replace Broken Glass on a Picture Frame: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    • Apply rubbing alcohol to a microfiber cloth.
    • Rub the edges of your glass carefully to remove any marks you created.
  8. How to Replace Broken Glass on a Picture Frame: 步骤 8 中的图像 1,2 How to Replace Broken Glass on a Picture Frame: 步骤 8 中的图像 2,2
    • Place the top of the glass in the picture frame.
    • Lower the bottom of the glass into the frame.
结论
To reassemble your picture frame, follow step one in reverse order.
Kirk Mills
于10/06/22注册
157 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 58
总计 2,608
