跳转到主内容
How to Replace Big Berkey Water Filters
你所需要的
  1. How to Replace Big Berkey Water Filters, Filters: 步骤 1 中的图像 1,2 How to Replace Big Berkey Water Filters, Filters: 步骤 1 中的图像 2,2
    • Take the top half of your Berkey off, and place it to the side of your work station.
  2. How to Replace Big Berkey Water Filters: 步骤 2 中的图像 1,2 How to Replace Big Berkey Water Filters: 步骤 2 中的图像 2,2
    • Unscrew the White Elements by twisting counterclockwise.
  3. How to Replace Big Berkey Water Filters: 步骤 3 中的图像 1,3 How to Replace Big Berkey Water Filters: 步骤 3 中的图像 2,3 How to Replace Big Berkey Water Filters: 步骤 3 中的图像 3,3
    • Unscrew the Black Element filters by twisting the black washers counterclockwise.
    • Remove the filters from the top compartment.
  4. How to Replace Big Berkey Water Filters: 步骤 4 中的图像 1,2 How to Replace Big Berkey Water Filters: 步骤 4 中的图像 2,2
    • Clean both the top and bottom tank compartments with a sponge.
    • Make sure to scrub both compartments clean of any mineral build-up that may have accumulated.
  5. How to Replace Big Berkey Water Filters: 步骤 5 中的图像 1,3 How to Replace Big Berkey Water Filters: 步骤 5 中的图像 2,3 How to Replace Big Berkey Water Filters: 步骤 5 中的图像 3,3
    • Securely attach the priming tool to the Black Elements nozzle.
    • Push the filter nozzle against the tap for 10 seconds per filter to remove any impurities.
    • Run your sink water at a medium to slow flow-rate, to avoid water spraying everywhere.
  6. How to Replace Big Berkey Water Filters: 步骤 6 中的图像 1,2 How to Replace Big Berkey Water Filters: 步骤 6 中的图像 2,2
    • Leave equipment to air dry.
  7. How to Replace Big Berkey Water Filters: 步骤 7 中的图像 1,3 How to Replace Big Berkey Water Filters: 步骤 7 中的图像 2,3 How to Replace Big Berkey Water Filters: 步骤 7 中的图像 3,3
    • Place your new Black Element filters through the holes in the top compartment.
    • Continue to screw the washer around the nozzle to secure the Black Element in place.
  8. How to Replace Big Berkey Water Filters: 步骤 8 中的图像 1,3 How to Replace Big Berkey Water Filters: 步骤 8 中的图像 2,3 How to Replace Big Berkey Water Filters: 步骤 8 中的图像 3,3
    • Screw our new White Element filters over the nozzle of the Black Element filters, and repeat to attach all pieces securely.
  9. How to Replace Big Berkey Water Filters: 步骤 9 中的图像 1,1
    • Enjoy your clean and purified drinking water from your Big Berkey for years to come.
结论
Shannon Cash
于03/03/23注册
169 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 75
总计 659
