跳转到主内容
How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel
你所需要的
  1. How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel, Bearings: 步骤 1 中的图像 1,2 How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel, Bearings: 步骤 1 中的图像 2,2
    • Use the Phillips #1 screwdriver to remove three screws.
  2. How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 2 中的图像 1,2 How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 2 中的图像 2,2
    • Use a flathead screwdriver to remove the screw.
    • After removing the screw, remove the black cap on top of the handle of the reel.
  3. How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 3 中的图像 1,2 How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 3 中的图像 2,2
    • Use a 10 mm socket wrench to remove the nut.
  4. How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 4 中的图像 1,2 How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 4 中的图像 2,2
    • With the nut now removed, remove the handle of the reel. You may need to gently wiggle it out of place if it will not remove.
  5. How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 5 中的图像 1,1
    • Remove this washer gently, You may also need to wiggle this piece out of place if it is stuck.
  6. How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 6 中的图像 1,2 How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 6 中的图像 2,2
    • Twist the drag dial off in order to remove it.
  7. How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 7 中的图像 1,1
    • Under the removed drag dial should be 4 metal washers. Simply pull them off the gold bolt.
  8. How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 8 中的图像 1,2 How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 8 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the two screws.
  9. How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 9 中的图像 1,1
    • After removing the two screws, remove the handle sides side plate of the reel. You may need to wiggle it off in order to remove it.
  10. How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 10 中的图像 1,2 How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 10 中的图像 2,2
    • With the side plate removed, take out the existing washer. It should be easy, but if not wiggle it free.
  11. How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 11 中的图像 1,2 How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 11 中的图像 2,2
    • Now flip to the break side of the reel. This is the opposite side of the handle.
    • Push this button and twist upward in order to remove the side plate. Remember to push and twist simultaneously.
  12. How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 12 中的图像 1,2 How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 12 中的图像 2,2
    • Remove the spool. It may take a little wiggle in order for it to line up with the casing around it and come out.
  13. How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 13 中的图像 1,3 How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 13 中的图像 2,3 How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 13 中的图像 3,3
    • Use a pair of pliers to remove the pin. There should be a big and small side of the pin. Remove the pin pushing from the smaller side in order to not strip the casing it sits in. It may take a little force, but try to be as gentle as possible.
    • After removing the pin pull out the bearing and replace it with a new one.
  14. How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 14 中的图像 1,3 How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 14 中的图像 2,3 How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 14 中的图像 3,3
    • Use a small flathead screwdriver to put tension on the spring and remove it. Remember to be very delicate removing the spring in order to not break or bend the spring.
  15. How to Replace Bearings in a Quantum Bill Dance Edition Bait Casting Reel: 步骤 15 中的图像 1,1
    • With the spring removed, remove the bearing and replace it with a new bearing.
结论
To reassemble your device, follow these instructions in reverse order. Remember to take your time, be very delicate, and be sure to assemble the device with all of the required pieces in order.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 37
总计 716
