跳转到主内容
How to Replace Basic Bag Lining
你所需要的
  1. How to Replace Basic Bag Lining, Bag Lining: 步骤 1 中的图像 1,1
    • Assess the old bag lining you will be replacing.
    • Consider color, material, and amount of fabric needed for the new lining.
  2. How to Replace Basic Bag Lining: 步骤 2 中的图像 1,3 How to Replace Basic Bag Lining: 步骤 2 中的图像 2,3 How to Replace Basic Bag Lining: 步骤 2 中的图像 3,3
    • At the seams, use your hands or sewing to carefully rip or cut out old bag lining.
  3. How to Replace Basic Bag Lining: 步骤 3 中的图像 1,1
    • Lay out old bag lining on fabric and measure out the size of the new bag lining, adding an extra 2 cm on each side.
  4. How to Replace Basic Bag Lining: 步骤 4 中的图像 1,2 How to Replace Basic Bag Lining: 步骤 4 中的图像 2,2
    • Fold new fabric in half to create one closed end for the bag lining.
    • Cut out bag lining based on measurements from previous step.
  5. How to Replace Basic Bag Lining: 步骤 5 中的图像 1,1
    • Stitch the two sides of fabric adjacent to the folded side to create a rectangle with one opening.
    • You can stitch by hand or use a sewing machine.
    • Use stitches small and tight enough to ensure new lining remains intact.
    • Finish stitching 2 cm from the end of the open side.
  6. How to Replace Basic Bag Lining: 步骤 6 中的图像 1,1
    • Fold over extra 2 cm from the opening of the new bag lining outward to hide the raw edge of the fabric.
    • With a needle suitable for sewing through your bag material, attach the bag lining with a straight running stitch around the mouth of the bag.
    • See the article How to Work a Running Stitch from The Spruce Crafts to learn how to do a running stitch.
终点
Ijada Nguyen
于01/26/23注册
133 声望
撰写一个指南
团队
UC Davis, Team 1-1, Morris Winter 2023 UC Davis, Team 1-1, Morris Winter 2023 的会员
UCD-MORRIS-W23S1G1
2 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 58
总计 2,197
