跳转到主内容
How to Replace Asus Transformer Pad TF103C Headphone Jack
你所需要的
  1. How to Replace Asus Transformer Pad TF103C Headphone Jack, Headphone Jack: 步骤 1 中的图像 1,1
    • Turn the power off.
    • Insert the plastic opening tool between the top and bottom covers of the laptop. The two covers are attached all along the outside of the laptop.
    • Use a thin screwdriver if you don't have an opening tool.
    • Gently pull upwards and carefully pry open the bottom and top covers.
  2. How to Replace Asus Transformer Pad TF103C Headphone Jack: 步骤 2 中的图像 1,1
    • Slide the tool along all four edges of the laptop and continue to pull the tool upwards to fully remove the bottom case from the laptop.
  3. How to Replace Asus Transformer Pad TF103C Headphone Jack: 步骤 3 中的图像 1,1
    • Remove the back cover once it is detached then set it aside.
    • Rotate your laptop to match the orientation shown in the picture to make the guide easier to follow.
  4. How to Replace Asus Transformer Pad TF103C Headphone Jack: 步骤 4 中的图像 1,1
    • Remove the tape and unplug the wire that attaches to both speakers from the soundboard.
  5. How to Replace Asus Transformer Pad TF103C Headphone Jack: 步骤 5 中的图像 1,1
    • Use the +J000 screwdriver to unscrew and remove the M2 screw and plastic bracket.
  6. How to Replace Asus Transformer Pad TF103C Headphone Jack: 步骤 6 中的图像 1,1
    • Remove the black tape from the ribbon cable and separate the cable from the soundboard.
  7. How to Replace Asus Transformer Pad TF103C Headphone Jack: 步骤 7 中的图像 1,1
    • Use the +J000 to remove the three mounting screws from the soundboard.
    • Keep the screws together and organized. (Label, if necessary).
  8. How to Replace Asus Transformer Pad TF103C Headphone Jack: 步骤 8 中的图像 1,2 How to Replace Asus Transformer Pad TF103C Headphone Jack: 步骤 8 中的图像 2,2
    • Remove the soundboard which has the headphone jack attached to it and replace with the new soundboard.
    • Once done reassemble your device, follow these instructions in reverse order.
结论
Tyler Ellis
于10/28/15注册
668 声望
创作了4篇指南
团队
UMass Dartmouth, Team 3-6, Shastany Fall 2015 UMass Dartmouth, Team 3-6, Shastany Fall 2015 的会员
UMASSD-SHASTANY-F15S3G6
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 661
