跳转到主内容
How to Replace Apple Magic Key (iPad Pro 12.9 inch 5th Generation)
你所需要的
  1. How to Replace Apple Magic Key (iPad Pro 12.9 inch 5th Generation), How to Replace Apple Magic Key (iPad Pro 12.9 inch 5th Generation): 步骤 1 中的图像 1,1
    • Hold the screwdriver vertically so that the flat end is facing the side of the key.
    • Make sure to place the screwdriver at the bottom right corner of the key.
  2. How to Replace Apple Magic Key (iPad Pro 12.9 inch 5th Generation): 步骤 2 中的图像 1,1
    • Apply a slight amount of pressure with the screwdriver to the side of the key.
    • Turn the screwdriver clockwise under the key until you hear a click.
    • Move the screwdriver back and forth along the side of the key, using a sawing motion.
    • Apply gentle pressure to the screwdriver. Applying too much pressure will break your key.
  3. How to Replace Apple Magic Key (iPad Pro 12.9 inch 5th Generation): 步骤 3 中的图像 1,1
    • Repeat the same procedure to the bottom left of the key but this time turn it counterclockwise until you hear a click.
    • Apply pressure very gently otherwise it might break the key.
  4. How to Replace Apple Magic Key (iPad Pro 12.9 inch 5th Generation): 步骤 4 中的图像 1,1
    • Once both sides are popped off, take your key and slide it to the front.
    • The circles at the back of the key are the slides and the square marks are the clips. It's important to slide the key from the top, downward, to not break the slides.
  5. How to Replace Apple Magic Key (iPad Pro 12.9 inch 5th Generation): 步骤 5 中的图像 1,2 How to Replace Apple Magic Key (iPad Pro 12.9 inch 5th Generation): 步骤 5 中的图像 2,2
    • Use the screwdriver to lift the metal bar from the key.
    • Set it aside in a safe place where it won't get lost.
  6. How to Replace Apple Magic Key (iPad Pro 12.9 inch 5th Generation): 步骤 6 中的图像 1,1
    • Place the flathead screwdriver under the bottom right corner of the plastic mechanism.
    • Gently apply pressure until you hear a "click."
  7. How to Replace Apple Magic Key (iPad Pro 12.9 inch 5th Generation): 步骤 7 中的图像 1,2 How to Replace Apple Magic Key (iPad Pro 12.9 inch 5th Generation): 步骤 7 中的图像 2,2
    • Repeat the same step under the bottom left corner of the plastic mechanism until you hear the click.
    • Remove the plastic mechanism.
  8. How to Replace Apple Magic Key (iPad Pro 12.9 inch 5th Generation): 步骤 8 中的图像 1,1
    • Apply a brush to the surface for any dust and debris.
  9. How to Replace Apple Magic Key (iPad Pro 12.9 inch 5th Generation): 步骤 9 中的图像 1,1
    • Clean any sticky leftovers under the unreachable corner spots of the key using a cotton swap.
  10. How to Replace Apple Magic Key (iPad Pro 12.9 inch 5th Generation): 步骤 10 中的图像 1,1
    • Spray the compressed air under the key.
    • Ensure the can nozzle is 5-10 cm from the surface.
    • This helps clear dust under the key.
  11. How to Replace Apple Magic Key (iPad Pro 12.9 inch 5th Generation): 步骤 11 中的图像 1,1
    • Slide the top of the plastic mechanism under the hooks and push it down until you hear a "click."
  12. How to Replace Apple Magic Key (iPad Pro 12.9 inch 5th Generation): 步骤 12 中的图像 1,2 How to Replace Apple Magic Key (iPad Pro 12.9 inch 5th Generation): 步骤 12 中的图像 2,2
    • Gently slide the top of the plastic mechanism under the hooks and push it down until you hear a click.
    • Do not slide downward. It can break the key.
结论
4等其他人完成本指南。
Baran
于01/12/23注册
313 声望
撰写一个指南
团队
3条评论
and there is an idea how to erase the paint from the keys to make them transparent in order to stick a sticker with a different language and for the backlight to work
Marcin - 回复
A word of warning, not all key caps go back like this.
The top left key (double-s thing), right square bracket, backslash key, left control, left option, right option and the little cursor arrows (I think that's all) go in differently. If you use the above technique, they will break.
There are two 'hooks' and two 'clips'
For these, the 'hook' is reversed and at two corners of the key-cap. This means you have to insert the key cap vertically behind the butterfly mechanism to let the butterfly-lugs engage the 'hooks', then fold the key cap down flat onto the butterfly so the 'clips' lock onto the other pair of butter=fly lugs.
Most are the 'reverse hooks. at the top edge of the key-cap, so two top corners, with 'clips' at bottom edge of key-cap, but the cursor arrows are mostly "hooks" on left (iirc) and 'clips on right; the up and down arrows are reversed, and I can't remember which way round, so you do need to check carefully.
Andy - 回复
Can you remove, replace and or clean the track pad?
James - 回复
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 124
过去 30 天: 414
总计 4,142
