简介
Having a clean air filter in your 2007 Toyota Corolla is crucial for optimal operation. However, over time the filter will become clogged with dirt and debris, and needs to be replaced to keep your car functioning like it should.
Often times, car dealerships and mechanics charge extreme amounts for simples fixes or replacements, and air filters are no exception. This guide is intended to save you some money by showing you easy steps to replace your air filter in a 2007 Toyota Corolla. It is a relatively fast, easy replacement that should only take a few minutes and a Phillips #3 screwdriver.
你所需要的
Pop your hood using the hood latch.
Release the latch under the front of the hood.
Open and prop the hood.
另外一个人完成了本指南。
