跳转到主内容
加入维修社区 - 创建账户
How to Replace 2005 Toyota Camry Cabin Air Filter
浏览量: 5810
浏览统计数据:
过去24小时
9
过去 7 天:
35
过去 30 天:
139
总计
5,810
评论: 0
暂时还没有人对本指南发表评论。你想做第一个评论的人吗?
Go to guide comments
已完成: 5
5 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 0
暂时还没有人收藏(和订阅)本指南。你会是第一个收藏(和订阅)的人吗?
所需时间: 15 - 20 分钟
难度: 中等
特色学生指南
该指南是我们优秀学生的辛勤劳动的成果,iFixit的工作人员认为这个很酷。
Cabin air filters are crucial for clearing the cabin of bacteria and dust, eliminating odors, and ensuring adequate airflow for defogging.
Over time, the cabin air filter becomes clogged from dirt and debris. It may be time to replace the filter if your car is smelling musty, or your heating/cooling is ineffective. If you do not replace your cabin air filter, you may begin to breathe in harmful pollutants like pollen and dust while driving, which can be especially harmful to people who suffer from asthma or allergies. It will also be difficult to defog your windshield, reducing your visibility.
Toyota recommends replacing your cabin air filter every 15,000 miles, and they charge a premium to do it. Use this guide to replace the cabin air filter in your 2002-2006 Toyota Camry yourself, saving you time and money. Replacement cabin air filters can be purchased at your local auto parts store.
你所需要的
工具
    1. How to Replace 2005 Toyota Camry Cabin Air Filter, Cabin Air Filter: 步骤 1 中的图像 1,3 How to Replace 2005 Toyota Camry Cabin Air Filter, Cabin Air Filter: 步骤 1 中的图像 2,3 How to Replace 2005 Toyota Camry Cabin Air Filter, Cabin Air Filter: 步骤 1 中的图像 3,3
      • Turn off the car.
      • Remove the key from the ignition.
      询问修复机器人
      添加评论
    2. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 2 中的图像 1,3 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 2 中的图像 2,3 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 2 中的图像 3,3
      • Open the passenger side door.
      询问修复机器人
      添加评论
    3. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 3 中的图像 1,2 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 3 中的图像 2,2
      • Open the glove box in the passenger seat of your car, and empty anything inside.
      询问修复机器人
      添加评论
    4. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 4 中的图像 1,1
      • Use a Phillips #2 screwdriver to remove the single 16.2 mm screw retaining the rod hook on the right side of the glove box.
      询问修复机器人
      添加评论
    5. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 5 中的图像 1,2 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 5 中的图像 2,2
      • Detach the rod hook from the hinge.
      询问修复机器人
      添加评论
    6. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 6 中的图像 1,2 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 6 中的图像 2,2
      • Press inward on both sides of the glove box to release the stops.
      • Remove the glove box and set it aside.
      询问修复机器人
      添加评论
    7. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 7 中的图像 1,2 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 7 中的图像 2,2
      • Push inward on each side of the air filter to unclip it.
      询问修复机器人
      添加评论
    8. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 8 中的图像 1,2 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 8 中的图像 2,2
      • Slide the cabin air filter directly out of its compartment.
      询问修复机器人
      添加评论
    9. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 9 中的图像 1,3 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 9 中的图像 2,3 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 9 中的图像 3,3
      • Push on the bottom of the air filter to loosen it from the plastic frame.
      • Flip the filter over and push the side of it until it releases from the frame.
      询问修复机器人
      添加评论
    10. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 10 中的图像 1,1
      • Install the new filter by pressing it into the plastic frame.
      询问修复机器人
      添加评论
    11. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 11 中的图像 1,1
      • Slide the folds of the new filter towards one end of the frame so that the entire filter fits within the plastic tightly.
      询问修复机器人
      添加评论
    12. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 12 中的图像 1,2 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 12 中的图像 2,2
      • Slide the air filter into its compartment until it clicks into place.
      询问修复机器人
      添加评论
    13. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 13 中的图像 1,3 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 13 中的图像 2,3 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 13 中的图像 3,3
      • Push inward on both sides of the glove box.
      • Raise the glove box until it holds in the housing without support.
      询问修复机器人
      添加评论
    14. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 14 中的图像 1,2 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 14 中的图像 2,2
      • Pull down the rod on the right side of the glovebox and push the hook back around the hinge.
      询问修复机器人
      添加评论
    15. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 15 中的图像 1,1
      • Screw in the 16.2 mm Philips #2 screw that holds the damper rod in place.
      询问修复机器人
      添加评论
    16. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 16 中的图像 1,2 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 16 中的图像 2,2
      • Replace your items and close the glove box.
      询问修复机器人
      添加评论
结论
Enjoy the fresh air!
取消:我没有完成这个指南。
5等其他人完成本指南。
作者
与
Saorla Miller
于02/26/22注册
373 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 35
过去 30 天: 139
总计 5,810
