跳转到主内容
How to Replace 2005 Toyota Camry Cabin Air Filter
你所需要的
  1. How to Replace 2005 Toyota Camry Cabin Air Filter, Cabin Air Filter: 步骤 1 中的图像 1,3 How to Replace 2005 Toyota Camry Cabin Air Filter, Cabin Air Filter: 步骤 1 中的图像 2,3 How to Replace 2005 Toyota Camry Cabin Air Filter, Cabin Air Filter: 步骤 1 中的图像 3,3
    • Turn off the car.
    • Remove the key from the ignition.
  2. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 2 中的图像 1,3 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 2 中的图像 2,3 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 2 中的图像 3,3
    • Open the passenger side door.
  3. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 3 中的图像 1,2 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 3 中的图像 2,2
    • Open the glove box in the passenger seat of your car, and empty anything inside.
  4. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 4 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the single 16.2 mm screw retaining the rod hook on the right side of the glove box.
  5. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 5 中的图像 1,2 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 5 中的图像 2,2
    • Detach the rod hook from the hinge.
  6. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 6 中的图像 1,2 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 6 中的图像 2,2
    • Press inward on both sides of the glove box to release the stops.
    • Remove the glove box and set it aside.
  7. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 7 中的图像 1,2 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 7 中的图像 2,2
    • Push inward on each side of the air filter to unclip it.
  8. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 8 中的图像 1,2 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 8 中的图像 2,2
    • Slide the cabin air filter directly out of its compartment.
  9. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 9 中的图像 1,3 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 9 中的图像 2,3 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 9 中的图像 3,3
    • Push on the bottom of the air filter to loosen it from the plastic frame.
    • Flip the filter over and push the side of it until it releases from the frame.
  10. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 10 中的图像 1,1
    • Install the new filter by pressing it into the plastic frame.
  11. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 11 中的图像 1,1
    • Slide the folds of the new filter towards one end of the frame so that the entire filter fits within the plastic tightly.
  12. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 12 中的图像 1,2 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 12 中的图像 2,2
    • Slide the air filter into its compartment until it clicks into place.
  13. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 13 中的图像 1,3 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 13 中的图像 2,3 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 13 中的图像 3,3
    • Push inward on both sides of the glove box.
    • Raise the glove box until it holds in the housing without support.
  14. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 14 中的图像 1,2 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 14 中的图像 2,2
    • Pull down the rod on the right side of the glovebox and push the hook back around the hinge.
  15. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 15 中的图像 1,1
    • Screw in the 16.2 mm Philips #2 screw that holds the damper rod in place.
  16. How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 16 中的图像 1,2 How to Replace 2005 Toyota Camry Cabin Air Filter: 步骤 16 中的图像 2,2
    • Replace your items and close the glove box.
结论
Enjoy the fresh air!
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 32
过去 30 天: 122
总计 2,536
