跳转到主内容
How to Repair the Sparker on a Merlion Mini Torch
你所需要的
  1. How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: 步骤 1 中的图像 1,3 How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: 步骤 1 中的图像 2,3 How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: 步骤 1 中的图像 3,3
    • Use the screwdriver to remove all the 1.2 mm Phillips #1 countersunk screws from the torch.
  2. How to Repair the Sparker on a Merlion Mini Torch: 步骤 2 中的图像 1,2 How to Repair the Sparker on a Merlion Mini Torch: 步骤 2 中的图像 2,2
    • Open up the torch.
    • Set aside the empty side of the torch.
  3. How to Repair the Sparker on a Merlion Mini Torch: 步骤 3 中的图像 1,3 How to Repair the Sparker on a Merlion Mini Torch: 步骤 3 中的图像 2,3 How to Repair the Sparker on a Merlion Mini Torch: 步骤 3 中的图像 3,3
    • Pull the handle down as if you were to use the torch.
    • You will see one of the parts inside spark. This is the sparker.
    • Now gently remove the handle and set it aside.
  4. How to Repair the Sparker on a Merlion Mini Torch: 步骤 4 中的图像 1,2 How to Repair the Sparker on a Merlion Mini Torch: 步骤 4 中的图像 2,2
    • Grab your pliers and GENTLY tug the sparker towards the Merlion head until it is extended about a centimeter.
  5. How to Repair the Sparker on a Merlion Mini Torch: 步骤 5 中的图像 1,2 How to Repair the Sparker on a Merlion Mini Torch: 步骤 5 中的图像 2,2
    • Gently bend the sparker until it is positioned near the opening of the Merlion's mouth.
  6. How to Repair the Sparker on a Merlion Mini Torch: 步骤 6 中的图像 1,3 How to Repair the Sparker on a Merlion Mini Torch: 步骤 6 中的图像 2,3 How to Repair the Sparker on a Merlion Mini Torch: 步骤 6 中的图像 3,3
    • Grab the tube and gently bend it so it faces the opening of the Merlion's mouth.
    • Put the handle back on the torch.
  7. How to Repair the Sparker on a Merlion Mini Torch: 步骤 7 中的图像 1,3 How to Repair the Sparker on a Merlion Mini Torch: 步骤 7 中的图像 2,3 How to Repair the Sparker on a Merlion Mini Torch: 步骤 7 中的图像 3,3
    • Take the empty half of the torch and place it over the other half.
  8. How to Repair the Sparker on a Merlion Mini Torch: 步骤 8 中的图像 1,3 How to Repair the Sparker on a Merlion Mini Torch: 步骤 8 中的图像 2,3 How to Repair the Sparker on a Merlion Mini Torch: 步骤 8 中的图像 3,3
    • Use the screwdriver to put the screws back in the torch.
  9. How to Repair the Sparker on a Merlion Mini Torch: 步骤 9 中的图像 1,2 How to Repair the Sparker on a Merlion Mini Torch: 步骤 9 中的图像 2,2
    • Hold the torch upside down and position the butane above the torch's hole.
    • Gently press down for five seconds.
结论
Congrats! Now you can use your Merlion torch again.
3等其他人完成本指南。
Neel Kogali
于09/29/15注册
200 声望
撰写一个指南
团队
Cal Poly, Team 14-3, Green Fall 2015 Cal Poly, Team 14-3, Green Fall 2015 的会员
CPSU-GREEN-F15S14G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 25
总计 7,559
