跳转到主内容
How to Repair the Broken Toe Strap of a Fabric Sandal
你所需要的
  1. How to Repair the Broken Toe Strap of a Fabric Sandal, How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 1 中的图像 1,2 How to Repair the Broken Toe Strap of a Fabric Sandal, How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 1 中的图像 2,2
    • Draw a rectangle on the bottom of the sandal that centers the hole of the toe strap.
  2. How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 2 中的图像 1,3 How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 2 中的图像 2,3 How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 2 中的图像 3,3
    • Slice through three connecting sides at the bottom of the rectangle using a box cutter.
    • Keep your fingers away from the box cutter to avoid injury.
    • Create shallow slices to avoid cutting through the sandal.
  3. How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 3 中的图像 1,3 How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 3 中的图像 2,3 How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 3 中的图像 3,3
    • Insert a toothpick into the bottom slit.
    • Use the toothpick as a lever to wedge open the flap.
    • Use an extra toothpick if the first one breaks.
  4. How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 4 中的图像 1,3 How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 4 中的图像 2,3 How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 4 中的图像 3,3
    • Slide the toe strap through the hole of the sandal until you feel resistance.
  5. How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 5 中的图像 1,3 How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 5 中的图像 2,3 How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 5 中的图像 3,3
    • Flatten the toe strap against the insole of the sandal.
  6. How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 6 中的图像 1,3 How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 6 中的图像 2,3 How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 6 中的图像 3,3
    • Apply the glue to the toe strap and inside the flap of the sandal.
    • Wear protective gloves to avoid skin irritation.
  7. How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 7 中的图像 1,3 How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 7 中的图像 2,3 How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 7 中的图像 3,3
    • Close the sole flap.
    • Press the flap down until it is even with the sole of the sandal.
  8. How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 8 中的图像 1,2 How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 8 中的图像 2,2
    • Use the trigger clamp to tightly press the flap against the sandal.
  9. How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 9 中的图像 1,3 How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 9 中的图像 2,3 How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 9 中的图像 3,3
    • Tighten the trigger clamp by squeezing the trigger.
    • Leave the trigger clamp on the sandal to dry overnight.
  10. How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 10 中的图像 1,1
    • Remove the trigger clamp by pressing the quick-release button.
  11. How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 11 中的图像 1,3 How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 11 中的图像 2,3 How to Repair the Broken Toe Strap of a Fabric Sandal: 步骤 11 中的图像 3,3
    • Pour rubbing alcohol onto a paper towel.
    • Rub the paper towel over the shoe to remove pencil marks and excess glue.
结论
If you properly follow the instructions in this guide, your sandal will be repaired to a lasting, wearable condition.
Kulthum Lakha
于09/28/21注册
193 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 69
总计 2,594
