跳转到主内容
加入维修社区 - 创建账户
How to Repair and Refinish Wooden Legs on Mirror
你所需要的
    1. How to Repair and Refinish Wooden Legs on Mirror, How to Repair and Refinish Wooden Legs on Mirror: 步骤 1 中的图像 1,3 How to Repair and Refinish Wooden Legs on Mirror, How to Repair and Refinish Wooden Legs on Mirror: 步骤 1 中的图像 2,3 How to Repair and Refinish Wooden Legs on Mirror, How to Repair and Refinish Wooden Legs on Mirror: 步骤 1 中的图像 3,3
      • Inspect the damage from the chew marks.
      • If you have a mirror that is attached to the wood, be sure to cover the mirror to prevent damage. You can use painter's tape and cardboard to secure the mirror from damage.
      • Look for finer areas with smaller chewed up marks.
      询问修复机器人
      添加评论
    2. How to Repair and Refinish Wooden Legs on Mirror: 步骤 2 中的图像 1,2 How to Repair and Refinish Wooden Legs on Mirror: 步骤 2 中的图像 2,2
      • Sand and clean the wooden legs in need of repair.
      • Be sure to wipe away all excess dirt and debris before applying stain.
      询问修复机器人
      添加评论
    3. How to Repair and Refinish Wooden Legs on Mirror: 步骤 3 中的图像 1,3 How to Repair and Refinish Wooden Legs on Mirror: 步骤 3 中的图像 2,3 How to Repair and Refinish Wooden Legs on Mirror: 步骤 3 中的图像 3,3
      • Apply the wood filler using a putty knife or your fingers.
      • If you use your fingers, be sure to press the wood filler into the chewed marks
      • Then smooth over with your finger.
      • Wood filler does dry quickly, so work fast if you are not using gloves.
      询问修复机器人
      添加评论
    4. How to Repair and Refinish Wooden Legs on Mirror: 步骤 4 中的图像 1,1
      • Allow the wood filler to dry (anywhere from 15 minutes to 8 hours).
      • Be sure to read the instructions on the wood filler for the allotted amount of time.
      询问修复机器人
      添加评论
    5. How to Repair and Refinish Wooden Legs on Mirror: 步骤 5 中的图像 1,2 How to Repair and Refinish Wooden Legs on Mirror: 步骤 5 中的图像 2,2
      • Sand the filled area that its height is level the surrounding wood.
      • Sand the wood filler until it becomes smooth.
      • Be sure to sand the wood filler to match the same height and angle of the shape of the legs or furniture.
      询问修复机器人
      添加评论
    6. How to Repair and Refinish Wooden Legs on Mirror: 步骤 6 中的图像 1,1
      • Match the stain to the wood using a scrap piece of wood.
      • Minwax is the best brand to use with a variety of stains.
      • If you are not using gloves, be careful when staining because it can take multiple washes to get the stain off your hands and clothing.
      • Use gloves when staining.
      询问修复机器人
      添加评论
    7. How to Repair and Refinish Wooden Legs on Mirror: 步骤 7 中的图像 1,2 How to Repair and Refinish Wooden Legs on Mirror: 步骤 7 中的图像 2,2
      • Apply the stain to the wood using a small paintbrush.
      • Be sure to use a staining brush, you can find them in the aisle next to the stains.
      询问修复机器人
      添加评论
    8. How to Repair and Refinish Wooden Legs on Mirror: 步骤 8 中的图像 1,3 How to Repair and Refinish Wooden Legs on Mirror: 步骤 8 中的图像 2,3 How to Repair and Refinish Wooden Legs on Mirror: 步骤 8 中的图像 3,3
      • Allow the stain to dry (depends on the stain; oil: 12 hours avg or water-based: 3-4 hours).
      • It may appear shiny and wet, so keep the wood out of the way.
      询问修复机器人
      添加评论
    9. How to Repair and Refinish Wooden Legs on Mirror: 步骤 9 中的图像 1,1
      • Repeat steps 7-8 for the desired stain.
      • On this particular guide, the staining process took three coats.
      询问修复机器人
      添加评论
    10. How to Repair and Refinish Wooden Legs on Mirror: 步骤 10 中的图像 1,1
      • Apply polyurethane sealer and let dry completely for 24 hours before reassembly.
      • Be sure the read the back of the polyurethane sealer for the allotted time.
      询问修复机器人
      添加评论
结论
Don’t forget to reassemble your wooden furniture. In this guide, the mirror has two screws that secure the mirror to its stand.
取消:我没有完成这个指南。
2等其他人完成本指南。
Paula Lewis
于09/27/21注册
261 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 72
总计 1,654
