跳转到主内容
How to Repair an Upper Delamination
你所需要的
  1. How to Repair an Upper Delamination, Check the damaged area: 步骤 1 中的图像 1,3 How to Repair an Upper Delamination, Check the damaged area: 步骤 1 中的图像 2,3 How to Repair an Upper Delamination, Check the damaged area: 步骤 1 中的图像 3,3
    • Identify the upper part that needs to be repaired
    • For better pressing later, remove the insole.
  2. How to Repair an Upper Delamination, Remove glue residue: 步骤 2 中的图像 1,3 How to Repair an Upper Delamination, Remove glue residue: 步骤 2 中的图像 2,3 How to Repair an Upper Delamination, Remove glue residue: 步骤 2 中的图像 3,3
    • Use a rough piece of sandpaper to rub-off the remaining glue residue and to roughen the surface for enhanced glue adhesion.
    • Be careful not to damage the material above the glued sole edge.
  3. How to Repair an Upper Delamination, Prepare the glue: 步骤 3 中的图像 1,3 How to Repair an Upper Delamination, Prepare the glue: 步骤 3 中的图像 2,3 How to Repair an Upper Delamination, Prepare the glue: 步骤 3 中的图像 3,3
    • Follow the instructions of the 2-component glue.
    • Push-out both components of the glue into a small tray and mix the mass until it is equally merged.
  4. How to Repair an Upper Delamination, Coat upper and sole with glue: 步骤 4 中的图像 1,3 How to Repair an Upper Delamination, Coat upper and sole with glue: 步骤 4 中的图像 2,3 How to Repair an Upper Delamination, Coat upper and sole with glue: 步骤 4 中的图像 3,3
    • Using a small spatula, coat the prepared upper surface with the glue.
    • Note: We recommend to get support by another person to pull apart the sole from the upper.
    • Spread the glue equally onto the roughened area and the inside of the sole edge.
  5. How to Repair an Upper Delamination, Pressing both parts together: 步骤 5 中的图像 1,3 How to Repair an Upper Delamination, Pressing both parts together: 步骤 5 中的图像 2,3 How to Repair an Upper Delamination, Pressing both parts together: 步骤 5 中的图像 3,3
    • Let the glue dry while putting one hand into the shoe and grasping the sole with the other one.
    • Note: Follow the instructions of the glue used to know the exact drying time. In this example we held the parts together for 3 minutes and then let it dry for 24 hours.
  6. How to Repair an Upper Delamination, Finished and ready!: 步骤 6 中的图像 1,3 How to Repair an Upper Delamination, Finished and ready!: 步骤 6 中的图像 2,3 How to Repair an Upper Delamination, Finished and ready!: 步骤 6 中的图像 3,3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
结论
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
另外一个人完成了本指南。
Ben Blischke
于07/19/23注册
10,230 声望
创作了66篇指南
团队
INTERSPORT INTERSPORT 的会员
Community
25 名成员
创作了169篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 64
总计 1,028
